bad idle after cleaning tb
I went to clean my tb the other day (idle would "jump around" a bit if It wasn't completely warmed up so I thought it might help) and saw that the back of the tb was really dirty so I took it off to clean it. As I took the tb off I noticed there was no tb gasket and that the area of the Im where the tb attaches was fairly gunked up to. As I cleaned everything I noticed one of the gunk spots on the Im was actually a chip filled in by gunk. After putting everything back together the car started idling worse and was "jumping" badly so I went and got a tb gasket. After I put it in it started to idle much better but now it idles high, around 900-1k and once it warms up will jump a little between 800-1200rpm but eventually evens out. So it seems to me like my im is the problem. Could it be something else? Or should i start looking for another im?
Get intake/carb cleaner and spray it around the tb and intake manifold while running. When the idle changes then you found your leak.
Your iacv & fitv is probably the ones that need cleaning. https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
car, year, engine???
Same here! Just cleaned my IACV yesterday after getting my car and the random idle problem was gone
andybmuzik
Aug 9, 2013 08:23 PM
carloselpavo
23
Jun 20, 2008 08:22 AM
