Dual point to multi point PROBLEM
Old Feb 10, 2014 | 10:42 AM
Ef4doorwagon's Avatar
Default Dual point to multi point PROBLEM
Did the mpfi swap to my ef. I used a D16a6 head and intake manifold and dizzy and ecu. Ok so my car started up, but really sluggish low idle, then died after being on for 20 seconds, then i got Code 5. Which is the map. Since i used the si head, do i also need the si(pm6) map sensor?
Old Feb 12, 2014 | 08:30 AM
ej1995's Avatar
Default Re: Dual point to multi point PROBLEM
they use the same MAP sensor IIRC
Old Feb 12, 2014 | 09:21 AM
4drEF's Avatar
Keyboard Humorist
Either MAP will work. Did you mix up the B and C plugs when you moved the C1 to B10 and C2 to B12?
The MAP wires are the same on the SI and DX - C11, C14, and C15.
Maybe you mixed up the TPS and MAP connectors (they are the same type of connector if I remember)?
Possibly something is up with your vacuum lines from the MAP not going to the right place.
Old Feb 12, 2014 | 09:25 AM
Freemananana's Avatar
Should be as easy as moving the vac hose from TB to TB if you use the one mounted to the firewall. It's easy to mix the vac hose for the MAP and charcoal can up. So check that.
ENJOI
11
Aug 23, 2006 10:39 AM
B16A1-EF9
14
Aug 27, 2005 09:30 AM
1fst4
Jun 18, 2004 03:56 PM
rattletrap
May 24, 2003 04:27 PM
