shift linkage for B series swap into 94 Del Sol
Old Feb 10, 2014 | 04:05 AM
mikeljcarr's Avatar
Icon2 shift linkage for B series swap into 94 Del Sol
I understand that the shift linkage for the del sol is just a bit shorter. I found that I should get a set for a '95 Del Sol. I was going to order a set from Honda but it looks like there are 2 options; one set of numbers applies to the S and SI models with a second set of numbers that applies to the VTEC model. I assume I need to order the VTEC linkage but want to be sure before I order. Am I correct in that I need the VTEC linkage?
Old Feb 10, 2014 | 05:59 AM
carlos8's Avatar
Default Re: shift linkage for B series swap into 94 Del Sol
Yes, for b series swap you need the 94-97 VTEC sol linkage.
Also you can use others b series linkages. i.e. EM1
Old Feb 10, 2014 | 06:26 AM
94EG8's Avatar
Seagull Management
You need the VTEC linkage. Btw the Del Sol Linkage is actually longer.
CivicTT
Aug 11, 2010 11:15 PM
Eg2707
Feb 15, 2008 12:12 PM
terribl3jon
Northeast (Sales)
Sep 14, 2007 07:43 AM
digital sol
Sep 24, 2006 07:38 AM
Ratical
Jul 30, 2006 06:49 PM
