b16a2 with gsr tranny into a db
Old Feb 9, 2014 | 11:49 PM
raverx3m's Avatar
Default b16a2 with gsr tranny into a db
i have to drop a b16 in my 4 door integra while im rebuilding the gsr.
ive heard horror stories about it.
how bad is it for a daily commuter?
is it single cam slow or worse?
Old Feb 10, 2014 | 12:04 AM
lukasmccracken's Avatar
Default Re: b16a2 with gsr tranny into a db
B16s honestly are not that terrible honestly, they are nowhere near as bad as a single cam. It's obviously a lot better if its a b16a from an si or similar
Old Feb 10, 2014 | 12:09 AM
raverx3m's Avatar
its a b16a2 stock. with I/H/E and aebs intake manifold
i have a p30 ecu with knock sensor board for it
i know early 90s b16 cams are smaller than gsr what about b16a3 and b16a2 are cams same as gsr?
Old Feb 10, 2014 | 12:28 AM
gsr cams have a little bit more lift and duration than the b16a2s and all in all it will feel quite a bit slower than your gsr I'm sure. however, for a daily commuter you will be fine until your gsr is rebuilt.
Old Feb 10, 2014 | 05:58 AM
kyden's Avatar
what year integra is it? if it is a 3rd gen i wouldn't bother.
Old Feb 10, 2014 | 07:09 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
It'll definitely feel a lot slower for DD use...especially with the awful GSR gearing. The B16 lacks torque. Add taller gearing to that problem and now add the fact that its pulling a 4dr....and the motor will be dogged down.
But it beats walking.
Old Feb 10, 2014 | 07:15 AM
raverx3m's Avatar
So it it slower than a 1.5 liter mon vtec civic lx 4 door with all the options
Old Feb 10, 2014 | 11:08 AM
B serious's Avatar
?? No.
Old Feb 10, 2014 | 11:19 AM
raverx3m's Avatar
then it should be fine for dd lol
everyone makes it sound like itsa d15y8 or something
Old Feb 10, 2014 | 11:39 AM
B serious's Avatar
You mean a D16Y8? A B16A2 in a civic coupe isn't much faster than a D16Y8 in the same chassis till you shift into 3rd gear.
So...a 99-00 civic Si isn't MUCH faster than a 96-00 EX till you shift into 3rd.
Since your 4dr integra weighs probably a little more...if not the same as an EM1, and you'll have GSR gearing...it will be a kind of like a 96-00 EX until you start really building speed. The big issue with B16s is torque. GSR transmissions have really tall gearing. So you'll notice the engine struggling a bit when shifting. A B18C feels a LOT more torquey than a B16. The lack of torque will be ESPECIALLY noticeable around town.
So it will be slow. But no...not quite as slow as a D15B non VTEC LX.
Old Feb 10, 2014 | 12:50 PM
raverx3m's Avatar
i can live with that
i can still crack vtec haha
a really loooooong vtec
Old Feb 23, 2014 | 08:54 PM
raverx3m's Avatar
drove it around the block today and it is not as bad as alot of people are saying.
i would say its a bit better than a db8 with ls swap
picks up relatively easy
boltons and AEBS intake manifold. everything else is stock and stock b16 crome basemap
Old Feb 23, 2014 | 10:49 PM
hell0curry's Avatar
Nice, right on with the swap man. And that specs in your signature is mean!!!
Old Feb 23, 2014 | 11:00 PM
raverx3m's Avatar
that engine is gone. now i got 2 gsr engines with same problem spun bearings both need rebuild
picked the wrong shop to do the headwork and it was leaking oil
the db8 engine also visited a shitty mechanic and oil starvation then spun bearing...
but i will see how this one does.
so far i have been satisfied with the power for daily driving
Wilka
Feb 15, 2012 08:33 AM
jdmasfuk
Dec 7, 2009 04:15 PM
ekvtec831
Jan 29, 2004 05:56 PM
notstock93
Nov 19, 2003 10:02 PM
LB CRX
May 6, 2002 11:26 PM
