cleaned IAC valve, now have CEL P0505
Old Feb 9, 2014 | 02:46 PM
5.4ever's Avatar
Default cleaning IAC valve, 99 ex
P0505 issue came up after cleaning my IAC valve. Nothing was wrong with it before, I just felt like cleaning it for good measure..
Continued on post#8
Old Feb 9, 2014 | 02:51 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: cleaning IAC valve, 99 ex
I just take the iacv off, and spray spray spray!!
Old Feb 9, 2014 | 02:58 PM
THE GREEN CRX//'s Avatar
simple.. to clean this valve ^^
Old Feb 9, 2014 | 03:14 PM
5.4ever's Avatar
but will it affect the bad in a negative way if i do what he did? it just seems like its mor thorough and seeing as how its just two more bolts, it would be better this way. But i dont wanna throw off any calibration or anything. Thats what I want to avoid
Old Feb 9, 2014 | 03:15 PM
your not relly supposed to but honestly if you know what to do then your all good
Old Feb 9, 2014 | 03:25 PM
HondaPartsHero's Avatar
Technical Hero
Is your car an auto? That video is for a Y7 or a Y8 auto. Also never get carb cleaner or throttle body cleaner on the gasket like he did in the video it'll dry the gasket out and cause leaks.
Old Feb 9, 2014 | 04:27 PM
5.4ever's Avatar
yes mine an auto. and same year as the video...
decided NOT to do it his way and just spray TB cleaner in the holes...
Old Feb 9, 2014 | 05:40 PM
5.4ever's Avatar
Default cleaned IAC valve, now have CEL P0505
So earlier I checked my car for codes... I made sure P0505 was not there...
I went ahead and cleaned the IAC valve since I was cleaning the TB and I had easy access
After assembling everything, I start the car, and I feel it shaking. It shows a CEL. So I pull the 7.5 fuse and let it sit there.
After I put it back in theres no CEL and it feels better. I take it for a drive and 5 minutes later CEL come on. I check it and sure enough this code is there
I made sure the gasket was sput back on right. I cleaned it with TB cleaner and sprayed it into the ports/holes of the IACV
Did I damage it or what can it be? Thanks
Old Feb 9, 2014 | 06:19 PM
xile6's Avatar
Default Re: cleaned IAC valve, now have CEL P0505
Did you plug the clip all the way in?
Also make sire or dried out all the way or it could be shorting out internally
Old Feb 9, 2014 | 08:14 PM
Former User's Avatar
Only one thread per topic is allowed. Related threads merged.
Old Feb 10, 2014 | 01:27 AM
Technical Hero
Was the code for the IACV?
Old Feb 10, 2014 | 02:28 AM
5.4ever's Avatar
Yes, new code P0505 showed up, come here, look it up and sure enough its constantly related to the IAC valve. Seeing as how its the only thing I cleaned besides the TB, I mustve done a mistake somewhere. Today I will
remove once more,
clean it up even more thorougly
allow it to dry for 4 hours
purge coolant system(air may have been introduced to it via coolant lines)
check and recheck all hoses for vacuum leaks
One other thing. I did sea foam my car via brake booster hose, any chance this couldve been a culprit???
Thanks in advance
Bob Moore
Honda Civic (2001 - 2005)
Sep 16, 2018 09:03 AM
spray004
Jun 30, 2011 01:53 PM
w0ng_sta
Jun 28, 2006 03:03 AM
dshook
Feb 3, 2005 11:41 AM
Boofster
Dec 29, 2003 02:41 PM
