Benson sleeved ls block cheap
Up for sale is a benson sleeved ls block... Block is currently at 86mm and would need to go o 86.5mm as one cylinder is out of round. Also the block had cracked at one point and was welded back and fixed. The block was used for 2.5 years after. Only reason I'm selling is I had custom pistons made for 86mm before I found out one cylinder was out of round. Selling cheap because it has to go to 86.5 and of the previous fixed crack. 700 obo
You can see here ok the right hand side where it was welded
