Cooling Fan Issue
Old Feb 8, 2014 | 10:17 AM
Sixx23's Avatar
Default Cooling Fan Issue
Hey all.
I've been battling a slight cooling fan issue. I noticed my fans had stopped working a couple weeks ago. I tested my relays/fuses/fan switch and noticed they were fine, so I figured it was the fan itself. I bought, and installed a new fan today, and I'm still not getting power.
I'll tell you what I know:
The fuse under the hood is good. Its been tested and replaced.
The relay is good. Its brand new.
Jumping the fan switch does nothing.
However, going from the fan directly to the battery kicks the fans on.
Is there another fuse, possibly in the car, I'm missing?
Anybody have any suggestions?
Its a stock D16Y7.
Old Feb 8, 2014 | 10:30 AM
Former User's Avatar
Default Re: Cooling Fan Issue
What car?
Are we talking about both the radiator and condenser fans? Or just the radiator fan?
Old Feb 8, 2014 | 10:35 AM
Sixx23's Avatar
Sorry - It's a 98 Coupe - DX
It's just the radiator fan.
Old Feb 8, 2014 | 10:41 AM
What does this^ mean exactly?
Have you voltage tested fuses 17 (dash) and 57 (hood)?
Old Feb 8, 2014 | 10:51 AM
Sixx23's Avatar
I just read about jumping the fan switch to see if it activates the fan. Just connecting the two terminals in the fan switch with a paperclip/wire.
And - I wasnt aware of the dash fuse (17). The car didnt have a fuse cover, and Ive never been able to find the correct diagram.
As far as voltage testing goes, my multimeter is corroded so I was just relying on a small fuse tester. You just contact the fuse terminals, and it lights green if its good.
Old Feb 8, 2014 | 10:53 AM
You'll find fuse box diagrams in the FAQs sticky. Test both of those fuses.
Old Feb 8, 2014 | 11:34 AM
Sixx23's Avatar
Thank you. That was the problem (17 fuse)!
Turned out that the fuse also had to do with my whole climate control not working. Thank you very much.
Old Feb 8, 2014 | 11:56 AM
Old Feb 18, 2014 | 10:53 AM
Sixx23's Avatar
Reviving this as today it seems the fuse has popped again..
Where do I start?
Old Feb 18, 2014 | 11:29 AM
Is the A/C or cabin blower on when fuse 17 blows?
Old Feb 19, 2014 | 11:01 AM
Sixx23's Avatar
No, it's not.
Old Feb 19, 2014 | 11:44 AM
Do the A/C, the cabin blower motor, the mode control buttons, and the recirculation button work?
Is option slot 4 (C929) used in your dash fuse box?
fatl13ert
Oct 22, 2012 12:41 AM
G. Man
Classic Hondas
13
Sep 2, 2011 10:36 AM
Nino_eg6
Jan 28, 2009 02:28 PM
dragaholic
Jul 29, 2006 11:43 PM
iNetForce
Mar 3, 2006 03:48 PM
