Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2009 Honda Civic engine problems
Old Feb 8, 2014 | 07:43 AM
AlexandBrayden's Avatar
Default 2009 Honda Civic engine problems
we bought a used 2009 Honda Civic with 54000 miles and in a year we've put about 5000 miles on it. We change the oil every 3000 miles. We've recently replaced the tires and also the engine mount. Now the engine isn't working. Is it normal for an engine to go out with 60000 miles on it. My husband thinks our 17 yr old is too hard on the car. Any input is appreciated.
Old Feb 8, 2014 | 08:06 AM
97emsedan's Avatar
Default Re: 2009 Honda Civic engine problems
When you say the engine isn't working, you mean the car won't start, or just not making power?
Old Feb 8, 2014 | 08:14 AM
The car won't start.
Old Feb 8, 2014 | 08:33 AM
97emsedan's Avatar
Ok, I am not a mechanic, so I say check the fuse box and see if any fuses are blown, particularly the main power relay. It should be a big metal looking one in the engine bay fuse box. After that, if all is well, move on to the starter fuse. If neither of these are bad, you will have to get a professional to look at it.
97emsedan's Avatar
And see that the battery is connected and in good shape.
Old Feb 8, 2014 | 08:55 AM
The battery is working and everything comes on. A friend of my husband said he thinks our son ragged on it too much because there was oil all over the parking lot where the car stopped working.
Old Feb 25, 2014 | 06:07 PM
HFx_NightLife's Avatar
That sounds like someone either didn't tighten the oil drain plug and let oil all out. Worst case someone blew a rod through the block.
Msmax
Apr 24, 2024 01:53 PM
Cubafrmdanycs
Jun 26, 2016 10:28 AM
Cody Wilson
Apr 7, 2016 04:38 PM
cpt.carnage
Dec 1, 2009 06:52 PM
'88civic
Oct 31, 2002 12:56 AM
