Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire Pressure 16" OEM vs 17" Replacements
Old Feb 8, 2014 | 06:28 AM
John Haggerty's Avatar
Default Tire Pressure 16" OEM vs 17" Replacements
I picked up a set of take offs from a 2013 Accord. Rims and tires are basically new. Old rims were 16" steel. New tires are Michelin Primacy mXV4 215/55R17 on aluminum alloy rims.
What tire pressure should I run? How is that determined?
Thanks
Old Feb 8, 2014 | 08:09 AM
97emsedan's Avatar
Default Re: Tire Pressure 16" OEM vs 17" Replacements
Look on the sidewall of the tire. It has the recommended pressures shown there.
Old Feb 8, 2014 | 02:51 PM
Jjbaehr's Avatar
Tire side walls show max pressure not recommended pressure, 32psi is what you should run.
Old Feb 8, 2014 | 02:52 PM
Sidewall shows maximum pressure at maximum load. That is not the pressure to be run.
Old Feb 8, 2014 | 03:42 PM
97emsedan's Avatar
32lbs is what my tires are set to...is the info not listed on the door jamb on the drivers side?
Old Feb 8, 2014 | 07:53 PM
DaveSi677's Avatar
btw you realize your tire size won't be close to spec with that aspect ratio... just don't want you to notice later... Also you speedo will be off due to incorrect tire size.
LudeChild
Jan 3, 2005 08:31 AM
silverCRXTC
Jun 1, 2003 10:02 PM
DSC240sx
Mar 9, 2003 01:45 PM
Integra187
Mar 21, 2002 07:38 AM
