Civic wagon died while test driving
Old Feb 8, 2014 | 01:01 AM
Ef4doorwagon's Avatar
Default Civic wagon died while test driving
I have a 4wd wagovan, comes with D16a6 mpfi. I did a mini swap( z6 head nd im), used obd 0 to 1 jumper harness. I wired everything correctly. Anyways, i drove around for about 20mins, my wago ran weird, like it was "trying" too hard to accelerate, cant really explain. Then i made a left turn at a light and the car died on me and didnt start up again. Starter kicks in, fuel pump too. Checked all fuses, so i thought it was the dizzy( cuz i tested for spark using a spark plug attached to the spark wire, nothing)bought a tested one and still nothing. What could it be? Bad timing? Also the spark plug was burnt at the tip what does that mean? I used everything new( head gasket, valve cover gasket, wires, plugs etc). Also the car had like one and a half year old gas in it i never tookit out, i just put new gas and those gas cleaner things in it, so idk if that messed up my fuel lines or whatever. Any help is greatly appreciated!
Old Feb 8, 2014 | 07:25 AM
radex7's Avatar
Default Re: Civic wagon died while test driving
Did you open up your distributor to see if the rotor is attached and still OK? Mine fell off once...
Old Feb 8, 2014 | 04:19 PM
sstupid's Avatar
10 Year Member
If you were running old gas, your fuel filter might have clogged. Spray some carb-cleaner in the intake and see if it starts to fire. If it does, your not getting fuel.
Old Feb 9, 2014 | 12:41 AM
The rotor is still attached.
What do you mean by spray it in the im? Like open the throttle body and spray inside?
Old Feb 9, 2014 | 06:20 AM
ProjetEF's Avatar
It might be a timing belt position issue. have you double checked that ?
Old Feb 9, 2014 | 09:34 AM
sstupid's Avatar
10 Year Member
Take your intake tube off and spray some in the TB opening.
Old Feb 9, 2014 | 10:02 PM
Yeah i didnt double check my timing. Like i had the bottom crank lined perfect with the oil pump arrow, but the z6 timing belt was such a tight fit, as i was pulling it over the cam gear i feel like the crank might have moved a few teeth. But it still started up, just idled funny for a while... But could the burnt plugs mean my timing was way off?
tchandarlis
Sep 6, 2016 09:33 PM
kc_kc
Mar 12, 2011 05:21 PM
Jos3ph
Nov 13, 2008 04:35 PM
1990civichatchie
Sep 16, 2006 01:39 PM
ddd4114
12
Jun 12, 2006 07:16 PM
