need help to identify these crx parts? & where they go?
Old Feb 7, 2014 | 10:22 PM
crxaddikt's Avatar
Default need help to identify these crx parts? & where they go?
need help figuring out where these parts go exactly on a crx ?
i just want to find out where they supposed to go ?
this looks like some type of radiator support mount bracket ? or radiator stay bracket ?, but not sure if it goes on top or bottom or where exactly ?
its #27 in the diagram
this one could be something for the shift linkage ? or alternator through bolt bracket ? or something else ???
this one to me looks like a bracket to hold underneath the steering column cover or something ?
Old Feb 7, 2014 | 10:25 PM
Nerdskateful's Avatar
Default Re: need help to identify these crx parts? & where they go?
I think the top pic is from the bottom of the rad and the last pic holds the rack and pinion
Old Feb 8, 2014 | 02:11 AM
crxaddikt's Avatar
i was thinking that was from the bottom of the radiator maybe too,
but when i went to check on my car underneath the front, i could'nt see cause those plastic splash guards and the bottom of the bumper that mounts were both in the way,
so i would have to remove them to see the bottom of the radiator or where that mount bracket would possibly attach?
Old Feb 8, 2014 | 02:16 AM
jdmjunkieXL's Avatar
1st pic is a top radiator stay 2nd pic i dont know...3rd pic is goes under the steering colum
Old Feb 8, 2014 | 03:59 AM
crxaddikt's Avatar
i think the 3rd pic is for under the steering column also, cause i saw a pic of one that looked just like it which was holding something under steering column.
Old Feb 8, 2014 | 06:37 AM
JDp0wer's Avatar
The third pic looks like it holds the shift linkage to were the shifter connect under the chassis.
Old Feb 8, 2014 | 09:27 AM
jonGSR's Avatar
The large washer goes to the rear motor mount. The long bolt slides into the washer, then the bolt attaches the bracket to the motor mount.
The top radiator bracket is for some ef's that came with the smaller radiator. My first was an 88 std 4 spd model and it had this smaller radiator with that bracket.
The bottom bracket is for the rack & pinion. It is a bracket which holds the rack to the rear subframe.
Old Feb 8, 2014 | 09:32 AM
Creator's Avatar
Number one is exactly as you have it, and it is upper. You only need that one if you have the 3/4-1/2 size radiator.
Not sure on number two, perhaps a spacer to bolt a fan to an aftermarket radiator.??
Number 3 is in this pick....#13
http://www.hondaautomotiveparts.com/...ERING+GEAR+BOX
It holds the steering rack to the rear subframe
Old Feb 8, 2014 | 12:31 PM
THE GREEN CRX//'s Avatar
number three is the shift linkage bracket im pretty certain.. it goes under the car
Old Feb 8, 2014 | 01:49 PM
That bracket is number 4 in this diagram
Old Feb 8, 2014 | 05:09 PM
zrickety's Avatar
That spacer looks like it's for pillar seat belt.
Old Feb 8, 2014 | 08:14 PM
crxaddikt's Avatar
i also think that bracket is for the steering column, like you mentioned, cause i already have the bracket on my steering rack, cause without it i'm sure it would be moving around and stuff, but they both do look the same, and the one for the shift linkage looks similar too.
Old Feb 9, 2014 | 06:27 AM
ProjetEF's Avatar
These information seem good to me, i d'say the same
Old Feb 15, 2014 | 08:53 PM
crxaddikt's Avatar
turns out that radiator bracket i was wondering about does fit the crx si ?,
cause i was looking at the top of my radiator again, and noticed there was an extra peg sticking up to the left of the peg on the right side mount, and there was also a 10mm bolt in front of it on the radiator support and i held that radiator bracket up to it and sure enough it fit there perfectly, i just missed it the first time looking at it.
i'm not sure if it just matters on which type of radiator you have or not ?, maybe some have that extra mounting peg sticking up and others don't ?, i realise its not necessary to have that bracket since the normal ones on each side are good enough, but its good on mine cause the rubber on one mount wore away so it moves around and plus it was just a little loose moving around, so that bracket keeps it in place.
ZCHondaCRX91
Dec 2, 2011 07:57 AM
whole9
Jul 3, 2007 04:27 PM
zexhuffer
Mar 14, 2006 06:31 AM
SHG_EasyE
11
Mar 12, 2006 09:21 PM
GSblueRacing
Sep 14, 2003 10:48 AM
