Clutch Reservoir Question
Old Feb 6, 2014 | 10:23 PM
Mario Locatelli's Avatar
Default Clutch Reservoir Question
Ok, changed my clutch in my 95 accord.
Clutch is not engaging. (Another post already up about that)
Heres something I noticed. When I manually move clutch release fork and in turn the slave cylinder starts moving. I hear that air is escaping from the clutch fluid reservoir. Ive gotten another cap but it does the same tging. Is it supposed to be air tight? And could this be a possible reason (air in the line) the clutch isnt engaging?
Old Feb 6, 2014 | 10:36 PM
holmesnmanny's Avatar
Default Re: Clutch Reservoir Question
Did you open the system ? Yes, it should be air tight.
Old Feb 7, 2014 | 02:02 AM
Also if someone pushed the clutch while the slave was disconnected it could have damaged it.
Old Feb 7, 2014 | 07:04 AM
Damaged what?
And would I need to replace the whole reservoir?
Old Feb 7, 2014 | 11:36 PM
I can only help if you answer my questions. I don't like giving out bad advice. I can only advise based on what you say.
Inextricabledrvr
Aug 22, 2007 07:35 AM
xunkn0vvnx
Mar 30, 2005 09:23 AM
Perfourmance
Nov 16, 2004 11:08 AM
DSGB.
Mar 19, 2003 02:40 PM
