My build thread
Pretty much last august i parted out my old setup now im in the middle of rebuilding the car to run in the BRMS drag series and just have the car to enjoy. The theme behind this go around was to build a street car with track features if you have any questions just ask...... March 1st i plan on putting the motor in then car goes to Clockwork Motorsports LLC
for some last minute fab worx then around March 15th off to rlz for some last minute wiring and tune !!!!!!!
UNDERHOOD
B16 head with ferrea valves , supertech spring and retainer with rlz valve job!
Block is a GSR with an ls crank 84mm A.E.B.S sleeved eagle rods wiseco pistons. ( all of my motor work was done at rlz)
B16 S4C non LSD Transmission with Comp stage 5 x plate with comp 8lb flywheel
Edlebrock Victor x Manifold
Edelbrock Fuel Rail
Wireworx harness
AEM 320 Fuel Pump
Deatschwerks 1300cc Injectors (still have to buy)
Precision 44mm wastegate (need one more)
Synapse BOV
Vibrant (850hp) Intercooler
Borg warner s300sx turbo
Tempest racing twin scroll manifold (have to pay off)
Blox Fuel Pressure regulator
Ebay Charge Piping
Tri Point sway bar
Blox Cam Seal
Skunk2 Purple valve cover washer kit + fender kit
EXTERIOR
Rota auto xs
Option Racing Carbon Fiber Hood
Option Racing Carbon Fiber Mirrors
Carbon frontend ordering (2-25-2014)
BlackWorks Front Tow Hook(Purple)
SUSPENSION
Skunk2 Sport Shocks with Adjustable Skunk2 coilover sleeves All Around
Blox Camber Kit (Front)
BlackWorks Rear Lower Control Arms (Purple)
Blackworks Rear Lower Tie Bar (Purple)
INTERIOR
NRG Steering wheel hub w/ NRG Hub lock
Momo Tuner Racing Wheel
GlowShift 7 color Gauges(Boost Hooked Up/AirFuel Hooked Up/Oil Pressure Hooked Up)
6 point Purple Roll Cage (Not Welded)(No Rear Seats)
Wink Style Mirror
B&M One Piece Short Shifter + circuit hero extender
Aftermarket LED Gauge Cluster face plate
Detachable steering wheel with Hub locks momo
now for pixs:dancenana:
When we pulled the motor and other ****
Will add more as i get closer to getting done big thanks goes out to Rlz engineering and Clockwork and all of my friends that put up with my B%^ch while working on my car !!!!
UNDERHOOD
Edelbrock Fuel Rail
Wireworx harness
AEM 320 Fuel Pump
Synapse BOV
Ebay Charge Piping
Tri Point sway bar
Blox Cam Seal
EXTERIOR
Rota auto xs
SUSPENSION
INTERIOR
Wink Style Mirror
nonoy93cvc
11
Oct 8, 2005 09:08 AM
