valve seals?
i have a 91 civic dx
d15b1
230k, , did valve adjust , timing belt , new alt etc last year
thing runs like a top , but
around town not much of an oil issue
but if i do 85mph for an hour on the highway to and from work i go thru about 3/4 a qt of oil a day
i have some blue smoke on start up , so i'm guessin valve seals leaking oil into cylinder after shut down
can the seals be replaced with each cylinder at tdc?
what's the need for rope, compressed air etc that i keep reading about?
d15b1
The rope/air keeps the valves from falling into the cylinder and disappearing.
You'd feed the rope into the spark plug hole, then compress it slightly with the piston to hold the valves in place while you work.
Gravity.
The piston at TDC doesn't mean it's holding the valve in the closed position. In fact if you have piston to valve contact at any point you have a problem.
When you see it you'll understand. It wouldn't fall completely in but it would be enough to not have anything to grab onto if you're not careful. Might help to picture installing the retainers, keepers, and compressing the valve springs all at a lower level as opposed to having the valve sticking out (closed position) to give you the most room to work.
i see
does the cam have to be removed or just valve train?
debating, either keep spending $25 a week in oil or do it in spring
only driving the car in winter now so
i guess it's possible i'm getting blow by with the higher rpm, would the seals do the same?
cuz like i said, only consumes oil when run 85mph for an hour twice a day
maybe with the rpm consumption it could be the rings more so?
mmmmmmmm, shame since i've changed the oil relig every 3k with castrol gtx 5w-30
eh, too much of a guessing game , just gonna switch to valve maxlife 10w-30 and get what i can
well, did some searching , seems everyone says it's seals if it's startup blue smoke
ex
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/blue-smoke-startup-873553/
now, the oil consumption at high rpm is what has me wondering if it's both
ex
bought a 2011 mazda3 sport hatch with 20k for back up
wish honda still made a hatch but, no dice
plan on running this till it dies just for winter, with good snow tires it plows thru anything, and 13" are cheaper than 17"
unbelievable how cheap new cars are, i actually like driving my 20 yr old civic more, even tho i gota put oil in it every day for commuting
eh, thought about it but
i had the valvetrain off last year to replace the spark plug hole seals
should have done valve seals then
Blue smoke at startup is valve seals. Will have to remove cams spring retainers etc. If it's a constant blue smoke then its rings. Remove oil pan windage crank rods pistons then replace rings.
Sounds like you might have a combination of problems.
Leakdown test would really help pinpoint the problems.
You are right that smoke during startup is an indicator to the stem seals. When the engine sits for a while, the oil seeps past the worn seal and into
the combustion chamber. It can even happen on deceleration as well as idling at a stop light.
Worn piston rings smoke when driving. You usually get a low number on a compression test as well, but not always. This seems possible since you are losing oil during constant no stop-and-go drives on the highway.
One thing that you have left out is a PCV. If it's malfunctioning and it stuck open or clogged shut, then you will burn oil all the time.
I'm having a similar issue, smoke on startup, and during quick bursts of acceleration or when starting from a dead stop, compression on all cylinders is around 100 psi, give or take 3-5psi, dry compression test, I' m going to run another dry compression test, and then a wet one to see if the compression raises to see if my rings are worn, she is also running really rich, im thinking worn out injector or 2.
SOHC ZC Non-Vtec, DPFI
The engine has mileage man. Metal to metal contact isn't gonna cure itself. I agree it can be a number of problems, but blue smoke whether start up or not means fried piston rings. That engine needs a rebuild either way. Get over it. The only way you'll find out the truth is if you take the engine out and inspect stuff. Asking for information will only lead to idiotic debates with people who think they know it all when no one is inspecting the actual vehicle
Do you have soot on your bumper. If so, the issue isn't only on start-up.
