Help...Leak in Trunk
I know that the del Sol has a problem with a leaking trunk and I think I remember reading somewhere that you can replace some clips to fix this. Has anyone done this and if so, do you know what the part numbers are of the clips or other required parts. I need to fix this fast...the water level continues to rise.
Thanks in advance.
Thanks in advance.
I also had the same problem you have. I remember seeing a site about this but I forgot where it was.
For some strange reason, Del Sol's are prone to alot of defects.
[Modified by DarkSol97, 5:56 AM 10/29/2002]
look in the howtos at www.teamsolwa.com
Nope, the seal is in perfect shape...definitely the clips.
[Modified by jdmsol, 12:41 AM 10/29/2002]
hermanssol
Jan 26, 2008 05:42 PM
EG MikE
Jul 22, 2007 02:07 PM
Del Sol on Steroids
10
Jul 12, 2007 04:15 PM
Squallie
Sep 30, 2005 03:36 PM
