(p1259) where is vtec solenoid located?
Old Feb 6, 2014 | 09:33 AM
tdrjar's Avatar
Default (p1259) where is vtec solenoid located?
I've got a 1998 honda accord 3.0 coupe and I've got a code of p1259 , which i know has to do with the vtec solenoid but where is it located i can't find it in the chilton manual
thanks
Old Feb 6, 2014 | 12:48 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: (p1259) where is vtec solenoid located?
The VTEC solenoid valve is on the assembly where the oil filter mounts. However, P1259 can be due to a problem other than just the VTEC solenoid valve.
http://www.hondapartsnow.com/diagram...-v6-456524.png
Old Feb 6, 2014 | 08:00 PM
STIGLITZ's Avatar
P1259 is VTEC system malfunction but I bet you knew that, first off i would check the oil level, if the vtec oil pressure switch doesnt get enough oil it will trigger the P1259
Cameron707
Jul 18, 2015 05:20 AM
JuneBugDrfter
Feb 21, 2013 09:38 PM
tekstyle
Apr 7, 2008 11:42 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
DC2point0
Aug 30, 2003 07:39 AM
