Do I need tuned? Am I losing power?
Old Feb 5, 2014 | 06:13 PM
suburban_ninja's Avatar
Default Do I need tuned? Am I losing power?
So first off I have a 90 Crx Si with a z6 swap. I am running 20 over pistons stock crank mains. z6 head with supertech guides, supertech titanium springs, supertech std valves, and a bisimoto stage 2 cam, golden eagle cam gear. Also a aftermarket 4-2-1 header with stock cat to a magnaflow exhaust. Im running stock injection and ignition with a virgin p28 on a odb0 to obd1 conversion harness with a 4 wire o2 and a obd0 to obd1 distributor. My question to you tune heads is am I losing potential power with a stock p28? Possibly even bad fuel econ? I am just wondering if I need to chip a p28 and run a tune map on it to gain what I have invested or is it really not going to do to much? I have a feeling that mainly my virgin ecu is probably negating potential power because is may be correcting air/fuel/ignition because it is unaware of the lobe lift from the cam. I am just seeking some input and knowledge and help is appreciated. Thanks in advance.
Old Feb 5, 2014 | 06:30 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Do I need tuned? Am I losing power?
Yes to all your questions except the P28 correcting one - the ECU doesn't change as much as you think.
Old Feb 6, 2014 | 09:50 AM
Gunmetal_B20_Hatch's Avatar
Yes... That poor engine is running so lean.
Old Feb 11, 2014 | 03:07 PM
VegasInvasion's Avatar
I'm Huge In Japan
the ecu doesn't really adapt at all, other than minor STFT there are no learning parameters. I'm surprised you haven't blown it yet. Get a tune on that thing dude, you're missing a ton of power.
bakomack
Jan 2, 2009 04:36 PM
racingant
Jul 16, 2005 09:03 PM
upstatecrx
Dec 5, 2003 02:16 PM
halfpint
Jul 20, 2003 07:47 AM
