COLORED GAUGE BEZEL HELP!!!
Old Feb 5, 2014 | 10:50 AM
crazyhouse2011's Avatar
Default COLORED GAUGE BEZEL HELP!!!
So I'm taking apart my cluster to put in an omni tach, and i've seen millions of videos, but they all cut out the essential parts i need to see. I saw an aluminum bezel cover for your gauges on ebay, but after seeing the price I decided maybe I could just remove the bezel in there and paint it. Can anybody confirm if the black bezel just removes from the clear plastic casing after you remove the gauge cluster from the casing?
95 honda civic, d16z6, etc etc
if you don't know what im talking about its the black piece with 3 circles cut into it for your gauges, and sits between the gauges themselves and the plastic cover.
Old Feb 5, 2014 | 10:51 AM
Default Re: COLORED GAUGE BEZEL HELP!!!
i also don't want to take it apart yet because i dont have the gauge yet, so telling me to take apart the cluster to find out won't help.
Old Feb 5, 2014 | 01:05 PM
Can anybody up in here give me some feedback?
Old Feb 5, 2014 | 01:41 PM
Okay so I see it's all one piece, but I feel if I remove the clear rings on the backside, and either remove or cover the warning lights, and then tape off the parts I don't want painted, I could paint it. the trouble is removing the clear plastic cover from the housing, i cant do it. I separated the housing from the cluster, so i can mess with the gauges, but I cannot access the bezel. Pls help.
Old Feb 5, 2014 | 02:38 PM
24TEN's Avatar
PHANTOM MENACE
Isn't only little locking tabs that hold it to the assembly?
Old Feb 5, 2014 | 02:51 PM
No, i already did that, so now i have the clear plastic (which is attached to the bezel) in one hand, and the cluster(which holds the gauges) in the other. Now I need to separate the clear plastic piece, ie the cover, from the bezel. The bezel and clear plastic piece makes a housing of it's own.
Old Feb 5, 2014 | 02:55 PM
DumpdEJ6's Avatar
I like the tuna here
I'm not 100% positive about EGs, but on EJs, CRVs, and Integras, the inner black housing area is removable. IIRC, there are several screws on the back that hold it on.
Old Feb 5, 2014 | 03:08 PM
my car is an ej1?
Old Feb 5, 2014 | 03:22 PM
24TEN's Avatar
PHANTOM MENACE
I'll look at a spare cluster when I get home, but I'm telling you up front if I find that it's a simple task I'm going to clown the F out of you.
Old Feb 5, 2014 | 08:35 PM
it looks like it is glued?
Old Feb 6, 2014 | 07:32 AM
Pics. See, i want the clear plastic piece separated from the black plastic bezel.
Photos taken with HP Chromebook 11 VGA webcam.
Old Feb 6, 2014 | 07:59 AM
wcfranklin's Avatar
i have a 1998 and mine was just held together with some clips and screws if that helps.
Old Feb 6, 2014 | 08:45 AM
There's no screws or screw holes.
Old Feb 6, 2014 | 10:59 AM
Can anybody here give me some information???????? I've provided pics, its pretty obvious what i want to do, and if its not please let me know. the new tach is gonna be in any day, and i don't want to have to deal with taking the cluster apart a second tim.e
Old Feb 6, 2014 | 11:27 AM
94_civic_dx's Avatar
i think there glued on in some spots maybe a try a heat gun and see what happens
Old Feb 6, 2014 | 11:37 AM
YEAH IT LOOKS LIKE THEIR GLUED. SO I GUESS I WONT BE ABLE TO REMOVE IT.
Old Feb 6, 2014 | 01:30 PM
DumpdEJ6's Avatar
If it's glued, then how are you supposed to replace the black piece with aluminum or fake carbon ones or whatever? It's got to come off somehow.
Old Feb 6, 2014 | 04:49 PM
try a heat gun and see what happens ive seen ppl change/color them so i know its possible but never seen or heard how to im curious to find out myself
Old Feb 6, 2014 | 06:21 PM
I DON'T HAVE A HEAT GUN DOE MANG!
Old Feb 6, 2014 | 07:11 PM
AdrianClayton's Avatar
I have a 2000 so it might be different but, I just undid the clips on the outer clear cover and lifted the black plastic off. There should be little plastoc clips on there somewhere.
Old Feb 6, 2014 | 08:47 PM
chillerice's Avatar
I just read a post where one guy had success by slowly and carefully cutting the glue with a razor blade then glued it back up.
just make sure all the moisture is out before glue it back.
Old Feb 6, 2014 | 08:52 PM
There's clips, but they are more just tabs that probably are used to situate the clear plastic cover and keep it in place. It looks like there's glue all around the cover where it meets the bezel. Guess I'm just gonna have to pass on this one.... I was really hoping I could take off the cover and spray paint the bezel blue.
Old Feb 7, 2014 | 02:48 AM
ill take a look at mine and see how to do it for u n ill let u know
Old Feb 7, 2014 | 12:32 PM
austinkli's Avatar
heat gun on the gauge cluster, not the best idea in the world....
use a razor to slooooooowwwwwly peel it off. Then just use some 3m adhesive spray to put it back on.
Edit: hey fool is this what you are trying to remove?
Old Feb 7, 2014 | 12:58 PM
Yes, son. But on a 5th gen not a 6th.
