B20 Swap into 93 del sol with b17 - What do I need?
I have a 93 del sol currently has b17 in it, I want to swap a b20 into it, aside from engine, transmission, ecu and harness, what all will I need to do the swap. Any advice is helpful. Thanks!
You already have a b series you only need change the ecu and depend on what obd your car and new motor is, a few things need to be correct. i.e. Distributor
Is your b17 toast? Why you want a stock b20? If you go ahead at least swap the heads b20v.
shady3260
Jul 24, 2010 06:00 AM
The Alchemist...
29
Nov 15, 2004 08:47 AM
