SC FS/FT: 2005 Honda Ruckus 210cc
Old Feb 4, 2014 | 02:44 AM
tao speaking's Avatar
Default FS/FT: 2005 Honda Ruckus 210cc
Ok so it looks like the time has come to maybe let my ruckus go. Been a project over the last year and a half give or take. A lot of time and effort has been put into the build along with over 7k in parts. Probably no more than 1k miles on total bike/parts since build. Here's what's been done.
2005 PowderCoated Frame
Newer Honda Seat
Newer Battery Box
NCY Lower Seat Frame
NCY Foot Pegs
NCY Rear Adjustable Shock
NCY Cam Type Throttle Unit
NCY Direct Coil Pack
NCY Intake Manifold
Kijima Turn Signals
R6 Smoked Taillights
Alien Ballistic Battery
FLP Kickstand
FLP V2 Front Frame Cover
2 Inch End Mirrors
8K HIDS
TrailTech
rPRO Monster Drag Bar
Swapt Chicago Front Hub
NCY Front Disc Brake Kit
NCY Stainless Steel Brake Line
Disk Drum Brake Levers
RRGS Low Down Forks
rPRO Axle Pullers
Ruck House Carter V1 12x8 12x4
Stainless Steel Gas Tank Cover
Composimo SS GY6 Fatty Mount Kit
Composimo Keyless Gas Cap
Composimo Fuel Pump Bracket
Composimo Lower Headlight Bracket
Composimo Intake Manifold Riser
PowerByMax V1 11pole Harness
DanMax Rear Drum Hub
MonsterGY6 Fatty Exhaust
And Now For The Motor. Motor was built by Fenders Cycle and Motorsport Inc in June/July 2013. It has roughly 150 miles just driving through town since build. It's a 210cc motor built to withstand drag racing. I know, couldn't refuse but wanted the power at the time. The motor is extremely strong, fast, and will throw you back. I haven't clocked top speed but the builder said the possibility is every bit of 80+ mph. Got over $1,500 alone in the build. Here's the list of parts on the motor build.
150 GY6 Engine Long Case
GY6 Stroker Crankshaft
GY6 Race Head
NCY 63mm Gasket Set
63mm GY6 Cylinder Kit
GY6 Generator
GY6 Final Shaft
A14 GY6 150 Camshaft
GY6 1004 Valve Springs
GY6 HD Starter Clutch
Vento Gear Set 16*36
GY6 Dr Pulley Variator
GY6 Adjustable Clutch
1500 RPM Compression Spring
1200-1106 13 Gram Roller Weights
GY6 Teflon Intake Manifold
28mm Mikuni Flatslide Carb
1.5 Needle and Seat for Carb
Mikuni Jet Needle
PFS 85in Throttle Cable
Looking for $6k or maybe trade + cash
Located in Spartanburg, SC.
Email: taoandsheng@yahoo.com
Call/Text: 864-497-3341
Old Mar 5, 2014 | 02:47 PM
Default Re: FS/FT: 2005 Honda Ruckus 210cc
bump
Old Mar 13, 2014 | 01:27 PM
bump
builthatch
Honda Ruckus and Scooters
49
Jul 18, 2021 08:45 AM
sgv_db
May 25, 2013 03:00 PM
Barbantus
Motorcycles
Aug 27, 2010 11:05 PM
Digital-R
Honda Motorcycles
10
Apr 29, 2005 04:29 AM
