Basic 1988 ef hatch d15b1 b16a swap need some advice,
hello everyone
i have a 1988 ef hatch with a d15b1 and i also have a b16a engine from a sir with y2 cable tranny that i want to swap in,
i allready did a dpfi to mpfi obd1 swap,
now some q's
i want to buy a ebay mounts kit, will i need any oem mounts for it to work?
is there a difference between the cable and hydro kit?
will my d15 axles fit the y2?
thanks!
now some q's
thanks!
You don't have to buy innovative mounts. HASport and other companies also make the mounts. "B-series into EF Chassis" is usually what they are called.
You don't need a kit for your car if you have a cable trans. It will work with the stock cable. The hydro kit coverts the cable to hydro obviously. Only needed with a hydro trans.
You will need B series axles. 90-93 non-ABS acura integra axles are the axle of choice.
I don't post here very often, but the lack of effort never stops amazing me. I have a build thread labeled with this swap. I also did a write up. This topic is also in the FAQs. It's covered 10 times a day.
rexracer626
Apr 19, 2009 08:27 PM
vectorsolid
May 24, 2008 05:44 PM
HASPORT EF/CRX B Mounts with CABLE TO HYDRO Kit and Intermediate shaft both axles and HASPORT EF-B s
Turbo EH2
Oct 25, 2006 10:00 AM
