Idle issue and valve clearance issues
Hey all, so last time I adjusted my valves I believe I did .003 on intake side and .006 on exhaust side. I tried searching online and I was getting different answers everywhere. Is this correct?
Also, randomly when I depress my clutch (typically when it happens most) my idle will rise and drop and repeat the process. At times it'll do it randomly. I removed the IACV and cleaned it. I don't have a cel. Could it be the IACV is bad?
Last thing, when I turn on my blower (no ac button), I notice water leaking under the glovebox. What causes this?
Tbh in my experience that's kinda normal for it to be a little higher then standard idle when rolling them coming down when you stop.
leaking heater core ! hell of a pain to replace
i just ripped all my ducting/HVAC out of my teg long and painfull day.
Does your car still have the under the hood sticker listing the specs ? i don't know lash specs off hand but i'm guessing it's a non-vtec. Tbh in my experience that's kinda normal for it to be a little higher then standard idle when rolling them coming down when you stop. leaking heater core ! hell of a pain to replace
i just ripped all my ducting/HVAC out of my teg long and painfull day.Indeed it is a non VTEC.
This nonsense started happening after I changed one of the hoses by the thermostat housing. Since my heater wasn't working, they had them on backwards, or in the wrong place at least. I took notice when I went to the junkyard and looked at another Integra.
I remember feeling water by the blower. Almost same place as heater core? It's strange. It does it randomly.
you could have a leak also but keep in mind the heater runs off the coolant tho
I'll try it again to see if it leaks and I can find out exactly where it is underneath the dash. I will bleed the system when I have off on Thursday.
Your clearances are correct for non-VTEC but they are on the tight side. 0.004 and 0.007 is the "middle" setting.
Those exact systems can arise if the lash is too tight (i.e. clearances are too low). Test the clearances again when the car is cold and make sure they are in spec. Your clearances are correct for non-VTEC but they are on the tight side. 0.004 and 0.007 is the "middle" setting.
If your non-VTEC B-series is anything like mine, those clearances are way WAY too tight.
Intake: .006 to .007
Exhaust: .007 to .008.
The actual numbers are in Metric and give a slightly wider "acceptable" range, but this is what I use for the sake of simplicity.
It's easiest to use the go/no-go system.
If your non-VTEC B-series is anything like mine, those clearances are way WAY too tight. Intake: .006 to .007 Exhaust: .007 to .008. The actual numbers are in Metric and give a slightly wider "acceptable" range, but this is what I use for the sake of simplicity. It's easiest to use the go/no-go system.
just set my b20 to those settings. 18 ftlbs on the locknut dont forget !
its pretty normal to clutch in and have the idle come up to 1100 or so, then when you stop moving it drops back down below 1000 rpm.
the other stuff sounds like leaking heater core. its a bitch mainly because of the **** u have to take apart to get there.. be careful when hooking up the coolant lines to the core that are on the firewall in the engine bay, the nipples are soft(lol giggidy) and and can become out of round and cause leaking hose connections
The book says (sticking with Metric for simplicity):
I: .15 to .19 mm
E: .17 to .21 mm
The sticker says:
I: .17 plus or minus .02 mm
E: .19 plus or minus .02 mm.
Same thing.
And both are close to the inch numbers I gave above:
Since inch feeler gauges don't quite match to Metric numbers, my inch numbers fall in the middle of the Metric ranges.
I use the "go/no-go" system, where I have the .006, .007, and .008 fingers splayed out at all times.
The numbers are the same in the book and on the sticker. The book says (sticking with Metric for simplicity): I: .15 to .19 mm E: .17 to .21 mm The sticker says: I: .17 plus or minus .02 mm E: .19 plus or minus .02 mm. Same thing. And both are close to the inch numbers I gave above: Intake: .006 to .007 Exhaust: .007 to .008. Since inch feeler gauges don't quite match to Metric numbers, my inch numbers fall in the middle of the Metric ranges. I use the "go/no-go" system, where I have the .006, .007, and .008 fingers splayed out at all times.
Thanks again.
I had forgotten/never realized that B18A and B18B were different. FWIW:
B18A
INTAKE: 0.006" - 0.007" (0.15mm - 0.19mm)
EXHAUST: 0.007" - 0.008" (0.17mm - 0.21mm)
B18B
INTAKE: 0.003" - 0.005" (0.08mm - 0.12mm)
EXHAUST: 0.006" - 0.008" (0.16mm - 0.20mm)
B18C
The B18B also applies to B20Z, obviously.
B18A
B18B
B18C
I had forgotten/never realized that B18A and B18B were different. FWIW: B18A INTAKE: 0.006" - 0.007" (0.15mm - 0.19mm) EXHAUST: 0.007" - 0.008" (0.17mm - 0.21mm) B18B INTAKE: 0.003" - 0.005" (0.08mm - 0.12mm) EXHAUST: 0.006" - 0.008" (0.16mm - 0.20mm) B18C INTAKE: 0.006" - 0.007" (0.15mm - 0.19mm) EXHAUST: 0.007" - 0.008" (0.17mm - 0.21mm) The B18B also applies to B20Z, obviously.
In general it is a very bad idea to change compression without also getting a full tune. You're up from ~9.5 to ~11.5 with just a change to those pistons. I'm not sure what exactly needs to be done but I imagine the timing will need tuning and DEFINITELY use 91 octane. A chipped ECU will not be enough unless you have had a custom tune done. I would not even trust a "custom" basemap except to get my car between my house and the tuner.
If you suspect you are running rich have a look at the spark plugs. While you are at it do a compression test.
B18A
B18B
B18C
B18A
B18B
B18C
In general it is a very bad idea to change compression without also getting a full tune. You're up from ~9.5 to ~11.5 with just a change to those pistons. I'm not sure what exactly needs to be done but I imagine the timing will need tuning and DEFINITELY use 91 octane. A chipped ECU will not be enough unless you have had a custom tune done. I would not even trust a "custom" basemap except to get my car between my house and the tuner. If you suspect you are running rich have a look at the spark plugs. While you are at it do a compression test.
The Chazzer
Honda CR-V & Element
15
Sep 12, 2012 04:24 AM
piggydog
Jun 19, 2008 03:30 PM
eluder33
Mar 1, 2005 10:47 AM
