ef civic clutch not disengaging
Old Feb 2, 2014 | 09:20 PM
standy xsi's Avatar
Default ef civic clutch not disengaging
just installed a new clutch on a ef honda civic d13b
used a clutch alignment tool
the problem is its not engaging fully and not going in to gear
start the car go to put in any gear and it will not go in but will start driving
try put it in reverse and it will cruanch
i didnt tourqe the pressure plate put did them up tight.
this is a perk job so i want to get it fixd
the clutch kit is clutch pro. part number KHN20004
it says honda civic, concert, crx 1.6l
put the clutch fit good on the input shaft. i have put in clutches before but there never been new. have i missed something that is ment to be done on a new clutch?
Old Feb 2, 2014 | 09:35 PM
instrument's Avatar
Default Re: ef civic clutch not disengaging
did you try adjusting the clutch cable.
Old Feb 2, 2014 | 09:55 PM
crazyhouse2011's Avatar
Sounds like your clutch cable is too loose.
Old Feb 2, 2014 | 11:20 PM
standy xsi's Avatar
i can hardly pull the cable up any higher
Old Feb 2, 2014 | 11:53 PM
standy xsi's Avatar
can you over tighten the pressure plate bolts
Old Feb 3, 2014 | 12:31 AM
standy xsi's Avatar
never mind
felipe69
Sep 16, 2009 10:34 AM
1990EFHATCH
42
Nov 21, 2008 09:30 PM
quik89
Sep 15, 2004 06:21 PM
bloodyknuckles
Jun 4, 2004 07:26 PM
Lo-Buck EF
Oct 21, 2001 12:17 AM
