87 crx hard start
Old Feb 2, 2014 | 02:00 PM
alsims86's Avatar
Default 87 crx hard start
I've just recently acquired an 87 crx pgmfi. When I got it it wouldn't idle and was hard to start. According to previous owner it has all new sensors, new dizzy, fuel pump, and coil. Apparently the car was carb originally and was swapped to fi. Looks like wiring harness and everything was swapped correctly. Now if I can get it started I can feather the gas slightly and it will try to rev up but backfires and sputters. I pulled the plugs and they are black as coal. But what seems strange to me is if I spray starting fluid into the intake it smooths out for a second and revs up smooth. I need some advice on what the problem could be please.
Old Feb 2, 2014 | 03:47 PM
instrument's Avatar
Default Re: 87 crx hard start
any cels? did you clean the plugs? does it rev over 3000?
Old Feb 2, 2014 | 04:48 PM
alsims86's Avatar
No cel. It will rev over 3000 but I have to feather the throttle lightly and rapidly and even then it's only maybe 3200 max. I tried cleaning the plugs but I think they are too far gone.
Old Feb 2, 2014 | 04:50 PM
alsims86's Avatar
I have tried a different ecu and it seems to be able to rev over 3000 if I spray starting fluid into throttle body while it's running. Not sure of how high though as I am under the hood working the throttle. With the other ecu I noticed no change in anything
Old Feb 2, 2014 | 04:56 PM
lsvtec hf-er's Avatar
Timing or wrong firing order.
Old Feb 2, 2014 | 05:31 PM
instrument's Avatar
sounds like you're in limp mode...does your cel light work? when in limp mode it runs super rich..so it'll backfire etc.
Old Feb 2, 2014 | 05:43 PM
alsims86's Avatar
Not on the dash but the ecu will throw codes. I unplugged the coolant temp and tried starting it and the lights on the side of the ecu lit up. Lights 4 and 2 were lit.
Old Feb 2, 2014 | 07:08 PM
instrument's Avatar
well the number four is your prob, check the faq.
Code 4 - Crank Angle Sensor
Top sensor in the dist. and is used for fuel control and misfire detection.
If the dist. base bearing starts failing, it will start heating the sensor(s) up, destroying the magnetism causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Old Feb 3, 2014 | 06:08 AM
alsims86's Avatar
It has a new dizzy. I don't think the code is 4. I got both lights on at the same time on the ecu when I unplugged the coolan temp sensor. I can clear them and they don't come back on
Veruka88
23
Apr 28, 2013 06:23 AM
v8killaz
37
Jul 24, 2010 10:30 AM
phillyk89
Oct 2, 2009 08:07 PM
dasnotjdm
May 22, 2003 05:07 PM
Driven
Jun 25, 2002 06:31 AM
