FS: Random Honda Parts, B16/GSR Goodies, Take a look!
Old Feb 2, 2014 | 01:46 PM
EF9_TryMe's Avatar
Default FS: Random Honda Parts, B16/GSR Goodies, Take a look!
So I've got a bunch of random Honda parts laying around in my Garage that are related to
OEM bizz, brackets, and some GSR/B16 Goodies. PM me for more info, and pics!
Engine/Hardware
GSR Block(Needs to be machined, Bare) - $75
GSR Girdle & 2 Outter Main Caps - $30
GSR Crank(virgin) - $200
GSR Cams - $70
B16 Intake Manifold - $30
GSR Oil Pan(-10AN Fitting for boost) - $50
B16 Oil Pan(Tapped for boost) - $30
B Series Flywheel - $40
D Series Clutch with Plate(Plenty of meat) - 30$
GSR Oil Pickup - $15
B16 Oil Pickup - $15
GSR Waterpump(Brand new) - $20
GSR Outter T Belt Cover(middle) - $25
GSR Oil Filter Housing with coolant nipples - $25
GSR Rear Main Seal - $15
GSR Thermostat Housing - $20
GSR Bottom Timing Belt Cover - $20
GSR PCV Black Box - $20
B16 PCV Black Box - $20
B16 Windage Tray - $15
Gsr Windage Tray - $15
B Series Crank Pulley(Came off my GSR) - $30
B Series Fuel Rail - $25
D Series Fuel Rail - $15
B16 throttle body - $30
GSR Rear Coolant Neck - $25
D16y7 Distributor housing with sensors, no rotor/cap(obd2a) - $20
D Series PS Pump - $30
D15b7 distributor with all sensors, no rotor/cap, has igniter(obd1) - $25
D Series Alternator - $30
Brackets. Mostly B, D
B Series Lower Alternator Bracket(Have 2) - $25 Each
B series Upper Alternator Bracket - $25
B Series Passenger side torque mount - $25
D Series Pass. torque mount - $25
Pass side B/D Series Mount - $20
D16Y7 P/S Bracket - $20
D Series AC Comp. Block Brackets(Not sure if it will fit B) - $20 Each (have 2)
D Series T Bracket - $15
EK Parts/Accessories
Power Steering Reservoir(96-98 EK) - $20
Radiator overflow tank(240sx?) - $15
EK Windshield washer fluid reservoir - $25
EK Gauge Cluster Bezel(Stock) - $25
96-98 EK Type R Knock off Grill - $25
9mm NGK Spark Plug Wires(Brand new literally) - $40
Evap Solenoid(Off 96-98 ek) - $15
Purge Canisher(off 96-98 ek) - $15
96-98 Stock Intake Air Box - $15
Old Feb 3, 2014 | 11:30 PM
KENetics1's Avatar
Default Re: FS: Random Honda Parts, B16/GSR Goodies, Take a look!
$30shipped for gsr oil pickup and baffle?
Old Feb 4, 2014 | 09:23 AM
maxwellmercer's Avatar
Interested in the y7 distributor, does it still have the coil and ignitor?
Old Aug 8, 2014 | 01:32 PM
HalFastTeg's Avatar
Do you have the oil cooler return nipple that threads into the block?
Old Aug 8, 2014 | 07:28 PM
racereaper7's Avatar
I'll take the gsr water pump if it's new
Is it a honda water pump?
EF9_TryMe
Feb 6, 2014 11:38 AM
ej8_99
Jun 25, 2011 04:13 PM
MENEZ
May 24, 2010 10:25 AM
C8V6C
Oct 8, 2005 05:30 PM
