97 DX coupe/LS intermitten issue,take look
Old Feb 2, 2014 | 09:07 AM
lowN$low's Avatar
Default 97 DX coupe/LS intermitten issue,take look
ok i have a 97 civic DX,with a Frankenstein LS swap in it,i call it that cause it has a
b18a1 block/head(has arp head studs already,pretty cool)
b18b1 intake manifold as my A1 didnt have the correct sensors
b18b1 manual hydro LS trans
obd2 b18c dizzy
obd2 LS ecu from an auto teggy
..ik ik not the best set up but u work with what u got when u need a car,my DD truck got totaled n i pieced this together from my project 90 Bswapped hatch that i couldnt get to run right and parts from my now license-less buddys 97 b18b1/turbo civic,i bought the car(say rolling chassie/parts) n we used my motor/exhaust but the rest of his motor components..anyway my question
-there are times it will run like ****,like hesitation and lack of power at below 2500-3000 rpms,above that she's fine and idles at 1500rpms..then there are times i go out n it will idle like a pissed off kitten at 1000rpms n not stumble at all..the inconsistency of this has me confused to be honest,i was told clean the IACV or check the FITV far as the idle goes..what does honda-tech think?
Old Feb 2, 2014 | 09:12 AM
Former User's Avatar
Default Re: 97 DX coupe/LS intermitten issue,take look
CEL codes?
Last full ignition system tune up?
Old Feb 2, 2014 | 09:37 AM
lowN$low's Avatar
Originally Posted by RonJ@HT
CEL codes?
everything was all dropped in the other week,fresh swap,and im getting a code for TDC sensor,i guess it got messed up or something in the distrbutor,also a 2nd code but i frgt what it was n dont have a scanner
Old Feb 2, 2014 | 09:52 AM
NotARaCist's Avatar
I never narc'd on nobody!
Uh, GSR distributors don't go on LS motors. Get the correct distributor.
Old Feb 2, 2014 | 10:10 AM
lowN$low's Avatar
it ran my buddys LS b1/turbo install just fine when it was his car vn had his setup in it
Old Feb 2, 2014 | 10:17 AM
Fix all CEL codes and then go from there.
GsrHatcher
Texas -OK -LA (Sales)
Jun 23, 2009 07:32 PM
MATiC
Dec 4, 2006 11:45 AM
chitsard
Mar 16, 2004 12:56 PM
boonacka
Sep 3, 2002 09:36 PM
