Cylinder head fixable?
Old Feb 2, 2014 | 07:37 AM
asianboi313's Avatar
Default Cylinder head fixable?
Cam cap 1 has damages on the cap and cylinder head it self. All other looks fine. Will sanding down the groove and polishing it again will save it?
Old Feb 2, 2014 | 07:41 AM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Cylinder head fixable?
You need to find a machine shop very good at line boreing and have it done. They look pretty poor. The belt was adjusted way to tight for those journals and probably cheap oil/starvation put it to death. Not a good head as far as I could tell you. Those are really deep grooves.
Old Feb 2, 2014 | 07:57 PM
kingofbattle909's Avatar
How does this happen?
Old Feb 2, 2014 | 09:35 PM
Discosteak's Avatar
usually timing belt too tight and using motor oil with poor pressure resistance.
Old Feb 2, 2014 | 09:38 PM
b20ricepower's Avatar
Damn thats pretty rough. Was the engine making any weird noise due to this? I have some decent wear but yea i'd say that definitely needs machined. If u can find a better core that would work too. Might be cheaper.
PleaseHelpMeGuy
Honda Civic (2001 - 2005)
Dec 27, 2017 02:03 PM
toxictom
Engine Machining & Assembly
May 25, 2017 06:04 PM
jmcmichael08
Oct 3, 2009 03:28 AM
dr_latino999
10
Jul 5, 2006 11:29 PM
jdstoledo
Apr 6, 2002 03:54 PM
