91 crx b16a 1gen no spark
hopefully one of you gurus can help me with this one....i have a 91 crx b16a 1gen that was set up for a supercharger then everthing go stolen so i am piecing it back together....i have a new dizzy off of a del sol si that from extensive research is supposed to be for this motor...i have power to the coil and the icm checks out fine just no spark...i have read there may be a ground issue or main fuse that needs to be replaced just wanted to know where to start before i dump more money into this thing....any suggestions?
ecu is one that came with the motor...i know it is 1st gen motor and it has run with this ecu before....but as to say i know i dont...is there some numbers on ecu i can look at to tell me?
munchies91crx
34
Sep 20, 2009 05:59 AM
turboem2
Mar 17, 2004 03:21 PM
