cylinder compression b16a3
Old Feb 1, 2014 | 03:38 PM
HOBSoCal1's Avatar
Icon6 cylinder compression b16a3
hey i need the compression for the cylinders for my 2000 civic si with the b16a3. any help will greatly appreciated
Old Feb 1, 2014 | 04:18 PM
B_Swapped93's Avatar
Default Re: cylinder compression b16a3
140 is the service limit and 200+ is the norm this can be found in the FAQ sticky tho...
Old Feb 1, 2014 | 04:24 PM
HOBSoCal1's Avatar
well just compression tested it unless my compression tester is no good. it blew 110 psi across the board. what dose this mean casue other than burning oil in vtec it runs fine
Old Feb 1, 2014 | 05:03 PM
NotARaCist's Avatar
I never narc'd on nobody!
Repeat the test "wet". That means put about a teaspoon of motor oil in the cylinder before testing. What numbers do you get when wet?
Old Feb 1, 2014 | 05:32 PM
HOBSoCal1's Avatar
ok i havent done it yet i will do it tomorrow but when i do do it and say i get higher numbers what will that tell me?
Old Feb 1, 2014 | 05:39 PM
NotARaCist's Avatar
It'll help pinpoint if it's your rings, or something else. If you have access to an air compressor, you should also do a leak-down test. That'll help really pinpoint your issue.
While you're doing tests, buy or rent a block testing kit. You can get them for cheap at your local parts store.
Old Feb 1, 2014 | 05:42 PM
HOBSoCal1's Avatar
ok never used a leak down test or a block tester i have an air compressor how do i do these test?
Old Feb 1, 2014 | 06:09 PM
NotARaCist's Avatar
** How-To/DIY ** - Leakdown Test
A block tester is simple to use, and should include instructions.
02BladeRider
Jul 7, 2017 05:49 AM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
IgnitionZ05
Mar 27, 2007 02:51 AM
dreamreaperx
Dec 20, 2006 02:01 PM
greenli0n25
Jan 26, 2004 07:29 AM
