1990 DX cluster lighting issue....
I have a 1990 Civic DX with a irritating issue that has defied repair for years...
The instrument cluster doesn't light up.
My dad and I have both checked, independently of each other and at separate occasions, the light bulbs themselves, the connections, etc.
Nothing. Bulbs are fine, no loose connections.
I just spent 8 hours tearing out the dash on the car, checking the wiring harness, and then reinstalling it.
No changes.
So, with a mild concussion from beating my head against the wall so much, I've been trying to find a wiring diagram to help me figure this out next time. However, I've been unsuccessful so far, despite several hours of browsing Google's results.
I'm at wits end with this, and I want to fix it. Can anyone point me to a wiring diagram, or provide some keen insight into what the hell is going on here?
EDIT: just rememberd some more details... (that's what I get for posting at 1AM...)
-The dimmer dial still worked, as the lights in the air conditioner button and the emergency flasher button would dim accordingly.
-The lights on the HVAC panel also didn't light up, but I can operate those by touch, so restoring the lights isn't a priority.
-Said lights in the HVAC panel would sometimes come on when I hit a bump just right, only to have them go out a few minutes later at the next manhole cover or pothole.
No changes.
No changes.
No changes.
When my dash lights went out, everything in the cluster died, all power to the dash was gone.
The problem I had was a loose fuse...
Check fuses, just put ur hand in there and push against all the fuses with the car on and if u see anything change then u know...
No, I checked, the dimmer is fine. ran a test by spinning the **** while using a multimeter in resistance-testing mode. It changed resistance the whole way.
Bserieskllr
Jun 3, 2005 01:48 PM
