Where can I buy steel charge piping
Old Jan 31, 2014 | 09:00 AM
averyvm's Avatar
Default Where can I buy steel charge piping
Hey guys,
I am having a hard time finding steel universal bends to use for my intercooler piping. I was looking on ebay and all I could find was aluminum intercooler piping kits. I was able to find some U J pieces on ebay but they are too thick and look like it would be used for exhaust. Thanks for you help.
-Avery
Old Jan 31, 2014 | 12:00 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: Where can I buy steel charge piping
http://www.mandrel-bends.com/catalog/contact-us.html
http://www.atpturbo.com/mm5/
http://www.acestainless.com/
Old Jan 31, 2014 | 12:09 PM
averyvm's Avatar
Thanks 2fast!
Old Jan 31, 2014 | 12:14 PM
2fast4u831's Avatar
I'm really 2slow
Originally Posted by averyvm
Thanks 2fast!
cheers!
Old Feb 1, 2014 | 07:02 AM
$MIKE$'s Avatar
Autozone.
Old Feb 1, 2014 | 12:48 PM
AFAccord's Avatar
Just curious, why steel for charge piping?
Old Feb 10, 2014 | 10:52 AM
averyvm's Avatar
I want to MIG weld it myself. I dont think you can MIG aluminum
Old Feb 10, 2014 | 10:53 AM
AFAccord's Avatar
Fair enough I suppose.
Old Feb 10, 2014 | 10:57 AM
averyvm's Avatar
Originally Posted by $MIKE$
Autozone.
Couldnt find anything at Autozone.
Old Feb 10, 2014 | 08:40 PM
Hidenplanvew's Avatar
You "can" mig alum, if your welder has a alum gun.
Old Feb 11, 2014 | 07:53 PM
bignorth's Avatar
Just buy U Bends in a smaller gauge, (18) And cut them to what you need. I believe http://www.mandrel-bends.com/catalog/ has them.
Old Feb 15, 2014 | 05:59 AM
1sick4g63's Avatar
It's called a spool gun and it's not really needed.
You can push an aluminum wire through a mig gun no problem. Typically you use 5356 wire because it won't bind as easily as a 4043. Some people also use 1 size larger tip. As the wire heats up it expands and clogs the tip. It's also ideal to run a Teflon liner. It helps guide the wire for a smooth transition. It can be done with the steel liner though.
And you need 100% argon gas.
thegatekeeper14
Welding / Fabrication
18
Apr 19, 2011 07:50 PM
runsfromdacops
Feb 14, 2010 05:25 PM
Muckman
Sep 5, 2007 07:59 PM
1FastCoupe
Aug 11, 2005 07:55 PM
therealciviczc
Jan 17, 2002 11:24 AM
