Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
vacuum leak.....
Old Oct 28, 2002 | 06:50 PM
Doctor CorteZ's Avatar
Default vacuum leak.....
tonight I swapped the booster/MC on my car to a 15/16" off an Integra RS.
everything goes fine with bleeding and install related things but...
I start the car up and HEAR the vacuum leak , it seems the booster/MC dont wanna seal.
on the lower side of the master cylinder where it meets the booster is a very large vaccum leak.
has anyone ever come across this before ?
I used Black Hi-temp RTV for a temporary fix BUT I'm not happy with that as a fix.
there is NO gasket between them , checked the old combo and they were the same way.
I got the two items off two different cars , any thoughts on that having any problems ?
I've changed MCs before and had no problem using the old booster , BUT this was with a MC ....
I'm at a loss , I dont like using RTV as a fix.
any ideas ???
Old Oct 29, 2002 | 04:21 AM
Default Re: vacuum leak..... (Doctor CorteZ)
anybody ??
Old Oct 29, 2002 | 04:54 AM
Todd Reid's Avatar
hi.
I installed a GSR master cylinder and vacuum booster on my hatchie. there is a rubber seal between the master cylinder and the vacuum booster. I left it out and there was a massive vac leak. ssssssssssssssssssss.
took it apart and put in the seal and it was perfect.
good luck
Todd
Old Oct 29, 2002 | 04:56 AM
Default Re: vacuum leak..... (Todd Reid)
thats what I thought it was , however the rubber seal is in place.
Mavrick
Aug 16, 2007 06:31 PM
redman223
Jun 3, 2007 03:58 PM
stevescivic
Jan 17, 2005 09:24 AM
