1991 Accord LX-What is the Best way to get traction in snow
Old Jan 30, 2014 | 01:57 PM
Chin Zimbabwe's Avatar
Default 1991 Accord LX-What is the Best way to get traction in snow
Hey gang. So I drive this 5 speed 1991 Accord LX and the other day she slid in snow. Even in wt ground, with fairly new tyres, she slides when taking off normally. What would you suggest I put for better grip in the snow and wet tarmac surfaces?
Thanks.
Old Jan 30, 2014 | 04:10 PM
CD5B2's Avatar
Default Re: 1991 Accord LX-What is the Best way to get traction in snow
Nitto SN2 is the best winter tire I've ever owned. Imo, they perform better than blizzaks. They do cost a bit more than the typical winter tire, but it's well worth it. Might want to check your sway bar endlinks links and whatnot too. Make sure everything's tight and not worn out.
Old Jan 30, 2014 | 04:25 PM
HonBeer's Avatar
install chains.
Old Jan 30, 2014 | 04:56 PM
bgdriver's Avatar
Welded diff and studded tires.
Old Jan 30, 2014 | 06:13 PM
CD5B2's Avatar
A front wheel drive car in proper running condition with good, non studded tires doesn't need chains. I have driven in numerous conditions (white outs, black ice, unplowed highways, mountain passes w/ a **** load of snow on them) and have gotten through just fine without studded tires or chains. Welded diffs are for drift cars.
Old Jan 30, 2014 | 07:54 PM
MAD_MIKE's Avatar
MM Gruppe B
Better tires, quit dumping the clutch, if it still slips, start off in 2nd rather than 1st.
02 accord
Nov 21, 2008 07:34 AM
GReddy212
Sep 22, 2004 11:08 AM
zak88lx
Sep 21, 2004 06:02 AM
98accordVTEC
Oct 6, 2003 12:37 AM
patastinky
May 27, 2003 05:29 AM
