NM 1993 honda prelude turbo 900+hp
Up for sale one of a kind drag/street prelude , only the best of parts and excellent fab work from a master tech . This car is ready to race needs nothing . Currently makes 964hp and 788lb/ft of torque at the wheels on a conservative 37psi . Very reliable will make a pass after pass with no problems. Below is a list of mods feel free to ask any questions as i am sure i am leaving things out:
Nhra 10 point roll cage with parachute mount
Agx coilovers
Gsr small brake conversion for 13" wheels
Front traction bar set up
Nhra battery box with cut off
Nhra fuel cell in the trunk with nhra fire wall
13x8 weld pro import wheels
Kirky racing seat
Aeromative a1000 fuel pump
10 feed to rail and a 6 return 1/2 bore fuel rail
Siemens 2300cc injectors
Sard fuel pressure regulator with liquid filled gauge
76mm blox throttle body and stock match ported intake manifold
Ported h22 head
Supertech incolnel flat supetech incolnel flat bottom exhaust valve
Supertech one piece flat bottom intake valves
Supertech valve springs with titanium retainers and locks
Type s cams adjustable cam gears
Arp head studs
Sleeved h series block
Grp aluminium rods
Arias custom turbo pistons and rings
Acl race bearings
Oem honda head gasket and all miss gaskets oem
Honda turbo: custom foward turbo facing turbo manifold
Twin tial 44mm wastegates
Precision 7694 ball bearing turbo with upgraded compresor wheel
Spearco water to air intercooler with custom water tank 3" aluminuim pipes
Tial 50mm bov
Competition clutch twin disc
Modded honda trans with carbon syncros
Quaife lsd
Custom wiring harness with hondata
Boost by gear
No lift shift
Prologger wideband and boost control
Autometer oil , boost , water temp gauges
Shift light tach
Msd 7al ignition box with pro coil and wires
$16,500
Call or texte at 5056925669
Agx coilovers
Kirky racing seat
Ported h22 head
Arp head studs
Grp aluminium rods
Acl race bearings
Tial 50mm bov
Quaife lsd
Boost by gear
No lift shift
Shift light tach
$16,500
Last edited by It Wasn't Me; Jan 29, 2014 at 02:01 PM. Reason: Merged multiple posts together and removed cl link.
$16500
HAHAHAHAHAHAHAHAHAHAHA
**EFFECTIVE IMMEDIATELY**
From todays date (3/18) onward; anyone selling ANY product in the marketplace will be expected to post a picture of their item for sale with a sign included in the photo. On the sign, should be your username, date and the words Honda-Tech.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Close this thread
Close this thread
While we do appreciate your effort in taking and posing the photos, you've forgotten the signage.
**EFFECTIVE IMMEDIATELY** From todays date (3/18/13) onward; anyone selling ANY product in the marketplace will be expected to post a picture of their item for sale with a sign included in the photo. On the sign, should be your username, date and the words Honda-Tech.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
