91 DA PS and AC belt tension specs?
Old Jan 28, 2014 | 07:42 AM
91akira's Avatar
Default 91 DA PS and AC belt tension specs?
So I'm gearing up and getting as much info as possible for this maintenance this summer. I'm trying to understand what is the proper tension for these belts. The numbers here are Greek to me. I've read some people just do the thumb method. (Twist 90 degree) Whats your thoughts on that or should I go for the factory recommendations? What do you guys do to check this? Thanks
Old Jan 28, 2014 | 07:54 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 91 DA PS and AC belt tension specs?
If you want to be exact they make a belt tension tool that's pretty cheap or just use the twist method.
Old Jan 28, 2014 | 10:30 AM
TheRealTegger's Avatar
I use my thumb in the middle of the longest run of the belt.
Do you have a bathroom scale? If so, then practice what 20 lbs feels like when pushing your thumb down on the scale. Your entire thumbprint should be flat on the scale.
Now adjust the belt so that same thumb-pressure results in a deflection of the belt of about 1/4" if a new belt, or about 3/8" if a used belt. Study the distances on a ruler so you can eyeball those distances while pushing on the belt.
Old Jan 28, 2014 | 02:15 PM
91akira's Avatar
Thanks guys. Where did you get those specs at for the 1/4 and 3/8?
Old Jan 28, 2014 | 02:58 PM
91akira's Avatar
The specs say under 20 lbs deflection force. I was looking some amazon ones and most of them starts at 30lbs. Couldn't find one under the 20lbs spec.
Old Jan 28, 2014 | 04:33 PM
1/4" is 6mm. 3/8" is 10mm. Check the figures in the photos above. Precision isn't critical for this application.
By the way, I forgot to mention that for some belts you need to use the fingertips of the index and middle fingers since there isn't any room for a thumb. Same approach applies.
dazebreak
Aug 12, 2015 07:06 PM
FeelTheBass
May 15, 2014 08:59 AM
sebTeggy
Nov 7, 2011 01:22 PM
hutcho3
Apr 8, 2011 09:00 AM
ALMXDUPINTEGRA
Aug 17, 2005 03:54 PM
