grinding noise on first acceleration after starting car
Old Jan 27, 2014 | 09:14 AM
valoskater420's Avatar
Default grinding noise on first acceleration after starting car
I have a 99 civic ex and when I start the car (any time of day), put it into drive and press the gas pedal it grinds once, and only once.
I have no idea what it could be. Ive had two different transmissions in there and the noise is still there.
I don't hear the noise when I'm at a dead stop and accelerate, only when I have the car off, start the car, then accelerate.
Old Jan 27, 2014 | 10:05 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: grinding noise on first acceleration after starting car
This is purely a guess but the one thing that is different from car off, start and go and car running then going from stop is the Starter.
I would think a sticky soleniod on the starter would make a lot more than just a one time grind noise but it is the one thing that is different between the two situations you mentioned. If anything, I would think it would be near constant once the car fired up.
If you've had different transmissions with no change then it's either motor, clutch or axle issues I would suspect.
Old Jan 27, 2014 | 11:34 AM
That's definitely a good start. I'll check my started and go from there. I do have an extra one I can put on to try.
Thanks
Old Feb 4, 2014 | 10:55 AM
Changed the starter, and still have the grinding noise. I don't even think this starters any better than the one I had lol
ej1ivi
Apr 26, 2017 09:44 AM
8VEYBEYB
Transmission & Drivetrain
Sep 8, 2010 08:00 AM
92tegzz
Jan 26, 2007 07:10 PM
ptype
Honda S2000
Dec 6, 2005 01:53 PM
Dooley
Jun 5, 2004 10:51 AM
