obd2a d16y7 in obd2b car
Old Jan 26, 2014 | 01:25 PM
tabrubaker323's Avatar
Default obd2a d16y7 in obd2b car
I researched this topic and found that the ecu is different along with the distributor plug and some iacv stuff. here's the deal, I have a serious oil burner on my hands and and looking to swap another y7 in it. I found a 2a y7. if I just take the long block and put the whole intake manifold set up and distributor off my 2b motor will everything else be the same? thanks in advance
Old Jan 26, 2014 | 01:29 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd2a d16y7 in obd2b car
Only difference is your distributor, just reuse it and swap the entire engine in.
Old Jan 26, 2014 | 04:17 PM
tony_2018's Avatar
Fish Twig
Yes everything will work as long as you swap all of the obd2b required parts.
Old Jan 26, 2014 | 04:39 PM
Technical Hero
The only part to swap is the distributor. Everything else is the same.
menappi
Mar 21, 2005 07:03 PM
blackdc
Nov 2, 2004 05:35 PM
ram4x4nut
Aug 27, 2004 10:26 AM
