My p29 build
Old Jan 25, 2014 | 05:22 PM
JDMequalslife's Avatar
Default My p29 build
alright so im near the end, finishing up my build for my eg hatch. Current parts as listed
block
-ZC sohc non v block bored .5mm over
-Pm7 .5mm over pistons
-acl race bearings
Head
-d16z6 head
-supertech valves .5 mm over
-comp zex valve springs
-stock z6 retaines
-skunk2 cam gear
Misc
-60mm throttle body on z6 manifold
-j2 one peice header
-gates timing belt
-blox fp
-oem....everything else haha
-rc 310 saturated injectors
-full b16 sir2 exhaust from the header back
-will be tuned on neptune
compression is gonna be around 12.5:1. Gonna be running e85. As for now gonna have the stock z6 cam
any suggestion, or tips?
will upload pictures tonight and tomorrow
Old Jan 25, 2014 | 05:29 PM
esteen2's Avatar
Default Re: My p29 build
Just use a stock z6 throttle body, lots of dyno info out there to show you don't need 60mm.
Old Jan 25, 2014 | 05:37 PM
Ive been hearing that alot. i have he 60mm laying around thats why im considering using it plus it matches up to the intake ill be using
Old Jan 25, 2014 | 06:15 PM
esteen2's Avatar
It's actually better if the throttle body is slightly smaller than the opening in the intake.
Old Jan 28, 2014 | 03:46 AM
projectTeG's Avatar
Port your oil pump and your running the through oil hole z6 crank right and not the single hole y series right?
JDMequalslife
15
Feb 7, 2014 04:21 PM
UltimateAmature
Mar 26, 2012 01:25 PM
blackhope121
Nov 13, 2007 08:20 AM
broke91hatch
Apr 16, 2007 12:32 PM
