More H23a Dyno testing by TURBOGIXXER TUNING
Old Jan 25, 2014 | 04:49 PM
zuptidi's Avatar
Default More H23a Dyno testing by TURBOGIXXER TUNING
So Some more testing goodies for you guys
brought to you by Turbogixxer Tuning
setup’
H23a Stock Block
RLz Head
pro1
Logic header vs 98vtec (Blakes Header)
Ported OEM Twin TB vs 58mm Vstack Xcessive
THE PARTS
Last time I was on dyno car made 246/181
I had originally ported partially the mani, the only diff I made was fully port the runners..
Before
After
Check out the Powerband man. (Insane what a lil porting does)
Run 41 vs 44 is the diff between Partial Ported and Fully Ported
Next up is Best of Logic vs Blakes header
Run 44 vs 53
Lastly the xcessive vs my twin tb
Run 53 vs 59
Im thinking about adding a reverse cone to the megaphone and see what happens..
As for the xcessive, might just be too big
Heres a vid for yall
Old Jan 25, 2014 | 05:20 PM
slowsleeper's Avatar
Default Re: More H23a Dyno testing by TURBOGIXXER TUNING
Thanks for sharing, not a fan of the xcessive IM for my own personal reasons but looks like your twin TB IM is a solid piece. There is neglible gains/differences in the headers as it's not a restriction yet.
Old Jan 25, 2014 | 08:53 PM
2fast4u831's Avatar
I'm really 2slow
good stuff man!!
Old Jan 26, 2014 | 05:28 AM
98vtec's Avatar
moderator emeritus
I'd love to see you run more compression and bigger cams and run that test again. I'm happy mine came in the same ball park as the logic but it looks a lot "bigger" than the logic too so it show fair a bit better once you try stuffing more out the exhaust
Old Jan 26, 2014 | 07:45 AM
Chugger's Avatar
Nice man. Keep up the good work.
Old Jan 26, 2014 | 11:57 AM
Uncle Dave's Avatar
It really does show how much these engines like to breath,nice job guys
Old Jan 26, 2014 | 12:13 PM
Charlie Moua's Avatar
Noted....thanks for sharing.
Q? Your twin tb setup... Ive thought about doing this , curious as to are the just stock dual 60mm your using?
Old Jan 26, 2014 | 04:35 PM
DDTECH's Avatar
Thanks to all parties for testing.
Blake, great job to see your header design looking good..
Old Jan 27, 2014 | 12:53 AM
eDm cRxXx's Avatar
Run 53 vs 59
Not shure I get it. Is the excesssive run 53 or 59?
And where can I find pics of the twin tb plenum/setup?
Old Jan 27, 2014 | 05:31 AM
DarKStaR5's Avatar
the xcessive is run 59, it lost power compared to his twin tb setup.
Old Jan 27, 2014 | 05:21 PM
LowBudgetBEe's Avatar
what xcessive 50 or 58 and was it with or without vstack plate
Old Jan 27, 2014 | 06:14 PM
zuptidi's Avatar
58mm with vstack and q45 throttle body.. the only thing i think that could have hurt it was port matching.. The IM needs quite some port matching but it 's not mine so i couldnt go at it..
Lowbudget your success with the xcessive is one of the things that pushed me to test it.. I had high hopes for it.
Did u already switch to 58mm ??
Old Jan 27, 2014 | 06:16 PM
zuptidi's Avatar
Charlie Moua
Theyre two 64mm H23a TB...
Old Jan 27, 2014 | 07:22 PM
1991_crxsi's Avatar
Nice to see another H23 holing it down! Should have mine tuned with DDTECH cams and a ported head in March… I will be ecstatic if I get numbers close to yours. My set up will be very similar, but your dual TB intake is quite an awesome performer! Great work on that! Its a pretty unorthodox design, but you have been making it work for a good while now, and its a proven killer. Unfortunately something like that, I cannot run on my Daily Driven car so I will have to run my ported OEM. BTW, flushing out the bottom of the intake manifold and porting it out so that the runners start where they do now was a good move. That is how I did mine, and I was vey happy with the way it performed compared to the other plenum style intakes out there (beat the mid range on my EuroR and held power up top better than the Skunk2).
Seeing your build is getting me excited for mine… NICE WORK! glad to see that stock bottom end breaking 250.
BTW… out of curiosity, where are your cams set at? I know every engine is different, and given that you have an RLZ head, it may have different deck height from a stock one… but, if you would't mind sharing I'd like to know.
Old Jan 27, 2014 | 08:52 PM
Uncle Dave's Avatar
And all this on Pro1 cams with a good cyl head
Old Jan 27, 2014 | 09:28 PM
1991_crxsi's Avatar
Crazy right… Very impressive. Can't wait to see how the DDTECHS do.
Old Jan 28, 2014 | 08:01 AM
DDTECH's Avatar
hoes should do well.
Old Jan 30, 2014 | 05:39 AM
Turbogixxer's Avatar
+5 on the intake and +2 on the exhaust. I do not know how it can help you because different manifolds would like different settings.
Old Jan 30, 2014 | 05:59 AM
1991_crxsi's Avatar
Just curious that is all. Thanks.
Old Jan 30, 2014 | 04:45 PM
DarKStaR5's Avatar
Martin for some reason i thought you were on pro2s, i guess thats why ive been scratching my head a little more lol. So could this manifold be better if running bigger cam?
Old Jan 30, 2014 | 04:50 PM
DDTECH's Avatar
KEnny, what were the v2v clearances on those settings?
Old Jan 30, 2014 | 07:08 PM
SpoonH2B's Avatar
x2
Old Jan 30, 2014 | 07:57 PM
zuptidi's Avatar
0.057 clearance from my v2v sheet
Old Jan 31, 2014 | 02:30 AM
bluehbcivic's Avatar
10 Year Member
5$ you have valve marks on the pistons ( radius of valve pocket ) on the exhaust side
Old Jan 31, 2014 | 04:14 AM
zuptidi's Avatar
i know i already do lolol...
