hard to go in 1st or reverse gear??
Old Jan 25, 2014 | 04:25 PM
evan221's Avatar
Default hard to go in 1st or reverse gear??
well i have a db1 teg with a b20/b16vtec swap with tranny and 3 stage clutch.
the problem that im having is that its hard to get it in 1st gear or reverse. i have to have the clutch around halfway to get it into to gear. ive also notice that the clutch cable is kinda tight with no play.
also when the car is off the car goes in gear fine.
Old Jan 26, 2014 | 10:01 AM
evan221's Avatar
Default Re: hard to go in 1st or reverse gear??
Old Jan 26, 2014 | 06:57 PM
crazyhouse2011's Avatar
Originally Posted by evan221
Go to a safe spot. Put the car in first gear with it off. Then push the clutch to the floor and start the car. Does the car move?
Old Jan 27, 2014 | 01:34 AM
m4xwellmurd3r's Avatar
Your clutch cable is too tight. At the clutch arm coming out of the transmission there should be between 1/4 to 1/2in of play between the rest and the point at which the throghout bearing touches the clutch.
Old Jan 27, 2014 | 04:08 PM
evan221's Avatar
thanks man loosen it and goes into gear without trying to force it with the pedal down
Old Jan 27, 2014 | 06:14 PM
No problem. Glad i could help.
single cam fan
11
Aug 31, 2008 11:29 PM
FuNkDrSpOt
15
Oct 15, 2007 03:03 AM
KekahaB18
May 15, 2005 09:17 PM
MCP486
Jan 13, 2003 03:43 PM
[626]95-GSR
Feb 15, 2002 02:52 AM
