Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 type s parasitic draw
Old Jan 25, 2014 | 09:08 AM
bigamouk's Avatar
Default 08 type s parasitic draw
Looking for a bit of help...
Battery has gone flat twice this week. I got the multimeter on to it and I've got a parasitic draw. I pulled out the fuse for the circuit causing the draw and checked the manual thinking I nearly had it sorted.
The manual just lists the fuse as 'Back Up' though. What is this? A back up fuse? A back up for another circuit?
I'm no electrician, or mechanic I suppose, but I'm stuck for what to do next!
Any help would be greatly appreciated!
Cheers.
Old Jan 25, 2014 | 11:34 AM
goldsy's Avatar
Default Re: 08 type s parasitic draw
That's just the backup fuse for the ECU.
When you have your multimeter on the battery testing for a draw, start taking out fuses one at a time until your draw on the multimeter reduces. That will be your bad circuit. You can troubleshoot the components on that circuit from there to determine exactly what is causing the draw.
Old Jan 25, 2014 | 11:36 AM
goldsy's Avatar
When I say pull the fuses one at a time, I don't mean pull them all out. Pull a fuse, look at the multimeter, put the fuse back in. Move onto the next fuse until you find the right one.
Old Jan 25, 2014 | 12:15 PM
bigamouk's Avatar
Yeh that's what I was trying but about 5 fuses in I pulled this one out and the amps dropped right down on the meter.
Don't know how that can be though if the fuse is just a back up?
Old Jan 25, 2014 | 02:57 PM
goldsy's Avatar
Originally Posted by bigamouk
Yeh that's what I was trying but about 5 fuses in I pulled this one out and the amps dropped right down on the meter. Don't know how that can be though if the fuse is just a back up?
A few other things to through that circuit. Do you have an aftermarket stereo? It runs through that circuit. As does the factory security system as well as a few other things.
Find a wiring diagram and find out everything on that circuit and troubleshoot them one by one.
Old Jan 25, 2014 | 03:12 PM
Jjbaehr's Avatar
Check the A/C compressor clutch relay, common draw on your vehicle.
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
rlh781
May 2, 2018 07:10 AM
XANTHODC2R
Classic Hondas
10
Jan 30, 2015 04:29 AM
niceprelude
Sep 2, 2011 06:58 AM
george34
Audio / Security / Video
32
Aug 17, 2006 12:47 PM
