eg suspension on ef
Old Jan 25, 2014 | 03:57 AM
LuckyJDM's Avatar
Default eg suspension on ef
I know I need to use eg forks but I have a question
If I use eg suspension on the ef with the front eg forks, the toe can still be set to factory spec correct? Im not going to slam my car just lower it about 2"
Old Jan 25, 2014 | 04:33 AM
instrument's Avatar
Default Re: eg suspension on ef
define "eg suspension" stock shocks and springs? after market? if so what?
Old Jan 26, 2014 | 06:53 PM
LuckyJDM's Avatar
koni gc
Old Jan 27, 2014 | 07:03 PM
Tyson's Avatar
When you lower the car, the toe changes regardless of the suspension is eg or whatever.
You still need an alignment, there's plenty of toe adjustment available.
Old Mar 15, 2014 | 07:04 AM
Efnit's Avatar
The eg forks and ef forks are the same exact fork except the eg is beefier. When I swapped mine out to eg coilovers on my 91 hatch I noticed that I can't go as low without preloading the crap out of the spring because they were made for a heavier car.
Old Mar 15, 2014 | 08:19 AM
Tyson's Avatar
Makes no sense.
Old Mar 17, 2014 | 10:09 PM
Canadian_EF's Avatar
http://www.ef-honda.com/ben/EFhybridsus.php
as far as forks go, there is no difference aside from the inner diameter where the shock body goes.
umm... as far as not being able to lower a coilover any further because blah blah blah... that's why you use the spanner wrenches.
Old Mar 18, 2014 | 09:34 PM
LuckyJDM's Avatar
Thanks guys was just making sure I can set it back to factory toe. Also I have GC coilover sleeves is there any way I can buy gc coilover springs with custom spring rates alone without the coilover sleeve?
patrickstar
20
May 22, 2013 07:25 PM
whokid_911
Feb 10, 2010 02:57 PM
604Squad
Apr 15, 2007 10:09 PM
Importracer_001
Suspension & Brakes
Jun 24, 2006 11:10 PM
jaydmcrx
Nov 15, 2005 05:07 PM
