Intake Cam twist posible?
good call, need to check that.
I believe the engine skip a tooth but not, advanced the intake cam 5 degrees on the gear and car went to normal. I realized that when put the distributor all the way advanced and work.
The keys and the cam grooves are perfect, but definitely the aluminum cam gears grooves have play side to side.
Going to buy a new ones, looking at BC and Blackworks.
Like I said - key ways... the problem with random keys is that they are usually not a perfect fit like the OEM keys are. Glad you found it though.
If you are going through all these issues why cheap out on those cam gears?
drumminforev
Nov 21, 2006 07:50 PM
Old_Honda
Jan 10, 2006 09:19 AM
