Transmission & Drivetrain Gearboxes, Differentials, Clutches
Whine when i accelerate in gear
Old Jan 23, 2014 | 02:09 PM
ponchox9's Avatar
Icon2 Whine when i accelerate in gear
I installed a new input shaft bearing and installed a new clutch kit..everything is working good but a week or two later i started getting a whining noise that sounds like reverse or a supercharger? in all gears only when its in gear and i give it gas. If i coast in neutral and give it gas there is no whine, at a complete stop and give it gas no whine, when i coast in gear there is no whine.. only when i give it gas in gear. What could it be?
Old Mar 14, 2014 | 06:25 PM
bking96's Avatar
Having the same problem with my 96 ej6
Bump
Sent from my iPhone
Old Mar 14, 2014 | 10:16 PM
slowcivic2k's Avatar
Default Re: Whine when i accelerate in gear
Improper gear lash. Provided it did not whine before you made your modifications, you have a mainshaft with too much end-play. a counter shaft with the same problem, or a differential that isn't clearanced properly.
Is this on a Chevy 3500HD?
b18c1ej8
Nov 29, 2010 03:26 PM
mrbuddha
Aug 16, 2010 07:53 AM
vtek9
Jul 10, 2007 12:48 AM
