What cams should i run?
Hi, looking for input. What cams will make most whp on this setup?
B16 / LS stroked
Head
P72 unported ( fresh valve job)
Supertech valve springs and retainers
ITR cams
Skunk 2 manifold
70mm TB
RSX injectors
Block
B16 81mm (stock sleeves)
LS crank
B16 rods w/ arp bolts
custom pistons Wiesco est. (12.5:1 comp)
arp main studs
arp head studs
Intake
3 inch piping into OEM air box K&N drop in filter
3 inch piping to OEM air box out the front bumper to bell mouth
Exhaust
JDM headers modified to 2.5 collector
3 inch mandrel bent to 3 inch magnaflow pan
Fuel
E85 or 93 oct ( getting 2 separate tunes)
Walbro intank 255
Ecu
chipped P28
Planning on spraying a 60-80 shot later on down the road. Thanks,
B16 / LS stroked
Head
ITR cams
Skunk 2 manifold
70mm TB
RSX injectors
Block
LS crank
arp main studs
arp head studs
Intake
Exhaust
Fuel
Walbro intank 255
Ecu
chipped P28
Are we talking about a B16A or B16B block?
Sweet troll post though. This build is impossible. B16 rods on an LS crank? LS crank in a B16 Block? that stroke would take custom rods in that block.
"bell mouth" aka Velocity stack in the front bumper
Your sig says you're selling a 9 sec car and you post about what cams for a stockish motor build with parts that will never work or match up? Come on guy quit lying to yourself and others.
Your Username should be catfish.
GTFO
GTFO
GTFO
GTFO
Stay Humble my Friend
Impossible build? Engine setup has over 2000 miles on it and counting ( DD ). Pistons have custom pin height placement. Don't doubt anything you hear. I've been around for a longtime in the Honda game. Yeah i know a bit but, I will always ask for advice / recommendations. You can never know everything.
Its one thing to have people come with suggestions, and that's welcomed, but c'mon..
If you're running a full custom motor it would be nice to know that. Anyone reading this thread w/o SPECIFIC build specs is going to draw the same conclusion I did... WTF is this guy talking about? This is impossible. This build is NOT an OEM parts build, which is what you made it sound like, plus you still didnt answer my question. What B16 block are we talking about? The LS crank in a A block is totally different from a B block. The A block takes a 77mm crank stock, that leaves 12mm to be made up for somewhere with the 89mm crank.
So lets try this again, what are the SPECIFICS of this build? I'll do an outline for you.
Block
Crank (mm stroke)
Pistons (bore, comp height, domes etc)
Rods (length)
Based off what you have built I am assuming its a B16A block w/ a ls crank, short pistons with a flat top and VERY short rods.
Your turn. Help us help you. Not trying to be a dick, just 99% of the time the OP has no idea what hes posting and has a "pipe-dream" build w/ 35:1 compression all planned out.
Block
Crank (mm stroke)
Rods (length)
I'll check it out. Just seems so impractical and pointless unless you need to do it to make tech specs for a particular racing class.
VtecCarHauler
Jan 5, 2015 06:01 AM
