Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 accord int. heater goes on only @ 2000rpm
Old Jan 23, 2014 | 10:13 AM
romko's Avatar
Icon2 03 accord int. heater goes on only @ 2000rpm
Can anyone help? My 03 accord 2.4 lt. interior heater only kiks in at 2000 rpm. otherwise it just blows cold air at idle. Thanks ahead for any replies!
Old Jan 23, 2014 | 03:42 PM
lazlong's Avatar
Default Re: 03 accord int. heater goes on only @ 2000rpm
Sounds like a bad heater core. Unless you can live with intermittent heat or do it yourself say goodbye to about $1000.
Old Jan 25, 2014 | 06:58 AM
Dārk83's Avatar
There are a lot of possibilities. If your coolant is full and your not seeing the temp reading staying low, then you can rule out a thermostat issue. I've seen the hot/cold actuator not working correctly keeping it from going to the full hot setting as well.
Old Jan 25, 2014 | 04:34 PM
johnsc2235's Avatar
Check your heater valve as well it maybe partially stuck, so when it flows slowly (idle) it doesn't heat very well but when the water pump pushes it thru it gets warm. Could be low on coolant or possible plugged heater core.
kiransr1992
Mar 7, 2017 05:04 PM
Ruy
Jan 1, 2014 05:26 PM
dcurcic
Nov 23, 2011 06:06 AM
Hertzler
Dec 15, 2008 10:33 AM
holotoftrouble
Jan 29, 2004 05:58 PM
