Suspension & Brakes Theory, alignment, spring rates....
Brake Problems
Old Jan 23, 2014 | 05:34 AM
michelle902's Avatar
Default Brake Problems
i have a 2002 accord 3.0 v6 coupe...im having trouble with my front pads making a metal on metal noise when the car is moving or just braking.... i have tried 2 different sets of rotors brand new and the pads are brand new.... i made sure nothing is rubbing including the splash shield and nothing is im 100% stumped on what is going on....it only makes the noise when you have everything back together.... any ideas what it could be???
Wearever Gold Ceramic Brake Pads
Power Stop Cross Drilled and Slotted Rotors
Old Jan 23, 2014 | 06:31 AM
rvn2svn's Avatar
Default Re: Brake Problems
Do the brakes get really hot from normal driving? That would point to a stuck caliper pin / piston or a brake pad that is not moving in its slide All if these could cause noise.
Are you sure those rotors are correct for your car? Could be that they are too wide for your calipers causing the brakes to drag.
Old Jan 23, 2014 | 11:58 AM
im going to check it out and yeah they are correct for the car as we tried to different sets of rotors and both did the same thing....its just weird both sides make noise but one side is just louder then the other
Landshark68
Apr 20, 2007 10:01 AM
SKOTie
Aug 10, 2006 02:59 PM
GSRNetics
Jul 9, 2006 08:33 PM
lo0nY
11
Feb 20, 2005 10:57 PM
endlessdv
May 17, 2004 07:44 PM
