push-button ignition 99 si
Old Jan 22, 2014 | 08:39 PM
LS-turboner's Avatar
Default push-button ignition 99 si
id like to bypass the ignition switch and clutch switch and put in a hidden push-button ignition. does anyone have a simple diagram? i have an idea of what to do, but a diagram would help. i searched but didnt see much.
do i just need a wire from + battery terminal to a button, then to the signal post on the starter solenoid?
the car is a stock 99 civic si w/b16a2
Old Jan 23, 2014 | 04:54 AM
Sccacivic1997's Avatar
Default Re: push-button ignition 99 si
Go on YouTube and type in mighty car mods push button start
Old Jan 23, 2014 | 07:46 AM
thanks man.
they didnt bypass anything though. they just spliced into the ignition switch. i want to bypass the clutch switch and ignition switch. just to buy me some time. ill eventually track down the issue and fix it right
Old Jan 23, 2014 | 11:03 AM
Grape Ape Guy's Avatar
you would still need a way to shut it off and kill the aux function.... key would be necessary
Old Jan 23, 2014 | 06:15 PM
tony_2018's Avatar
Fish Twig
You just turn the key to shut off the car...... All you need to do is jump the clutch switch. splice into the ignition harness. You need to find the wire that triggers the starter-cut relay.
civic-one
Jun 21, 2017 02:43 PM
Ryan559
Oct 6, 2010 08:41 PM
b18a1ef9
Aug 23, 2006 02:44 AM
bushrat
Jan 16, 2005 09:21 AM
Un0Turb0-WP
Oct 19, 2004 11:45 AM
