97 ex clutch adjustment or bad??
Old Jan 22, 2014 | 09:16 AM
rrdugas's Avatar
Default 97 ex clutch adjustment or bad??
so my 97ex coupe is having some trouble when i first get her going. I pull out from the first 2 or 3 stops in first and the clutch has some trouble grabbing and jerks pretty significantly. Once things are warmed up no problems at all. no jerking from stops and no slipping at all in any gear.
Also when still cold and jerking... once i am moving i notice no slipping at all.
This just happens when i pull out in first gear and am engaging the clutch. then stops completely after 5 min or so.
Is this a sign my clutch is going or do I simply need to make some adjustments
thnx
Old Jan 22, 2014 | 09:37 AM
kyden's Avatar
Default Re: 97 ex clutch adjustment or bad??
you probably have 1 or more of the springs in the disc about to pop out.
Old Jan 22, 2014 | 09:40 AM
rrdugas's Avatar
gotcha, so im assuming there arent any tricks to prolonging taking it apart as i'd like to just get a few more bucks and do a swap if i have to start taking **** apart. for now i've just been trying to be very easy on it but not seeming to matter much as its gotten worse.
how much damage will it cause if i just drive it till it breaks
Old Jan 22, 2014 | 10:55 AM
kyden's Avatar
mine did it for a few years until i decided to change it since i had the engine out anyways. it's kind of a roll of the dice really.
Old Jan 22, 2014 | 02:44 PM
HondaPartsHero's Avatar
Technical Hero
You clutch is on the way out, happened to my 96 Civic, changed the clutch and went away.
D Griff
May 29, 2010 07:10 AM
NH538DB8
Dec 29, 2006 04:34 AM
Jun 13, 2006 12:09 AM
Neptune
Apr 15, 2003 12:03 PM
skywlkr235
Aug 4, 2002 10:48 AM
