Help with next best upgrade
Alright guys I just recently traded my gsr for another long block. So instead of taking the previous owners word I tore it down to see what I had. Turns out I made a decent move...or at least I think.
B18C block
LS rods and crank
PCT 81.5mm pistons
B16 head
CTR cams
ITR intake and TB
That was the basic setup. I sent the head and had a valve job done. The head had already been ported. Valve springs and retainers appear to be supertech, as I can't see any markings to tell me otherwise. And the ecu is a chipped p28. I plan on re tuning ASAP because I'm not sure who previously tuned it but it runs very rich especially in Vtec. But my question is before I re tune where would be a good place to start as far as upgrading to see some power gains? I'm gonna be good with the numbers it puts down regardless I'm just looking for a fun but reliable daily driver. So I'm not looking for anything extreme, just somewhere to start so that I will notice something.
B18C block
LS rods and crank
PCT 81.5mm pistons
B16 head
CTR cams
ITR intake and TB
I have a short ram but it only has a come filter. And also I have a PLM big tube header. Not sure the exact style of the header but I had to trim my fan shroud for it to fit if that helps.
Those pistons
I'd swap those out (get P73-A0's 12:1ish) so you have more cam options later on. Your motor will like pump gas MUCH more too.
BPi Vstack on the SRI. And like F22 said a good header. Toda rep is hands down the best budget header on 1.8's
just my .02
just my .02
I second the p73-ao piston option. If you do the piston swap you might as well go .5mm over and get everything machined to avoid any surprises of barreled or oval cylinder walls. If you do that you might as well install arp rod bolts now you have a dependable engine with a nice powerband.
Sorry guys I didn't wanna get into a post that just seemed to rattle on about my setup but it does have arp rod bolts, full 5Zigen fireball exhaust, and the PCT's are already .5mm over. But i do like the recommendtion of the piston swap bc I'm running a cometic gasket thats .049" thick to keep compression down and I've noticed it seeping some oil out so I'd like to go back with OEM. But if I do swap pistons will it be a good idea to go another .5mm over on stock sleeves?
I've wondered the same thing. I didn't resurface the head or anything after I tore it down only because the previous owner claimed that both the head and block had been milled but he didn't know how much. So I was afraid of too much compression and didn't bother with it.
That motor w/ a set of Skunk2 stage 2's, or RM22's will put out a great usable power and be as reliable as stock.
Yea that's gonna be one my next moves is to check the head and block to find out exactly how much if any milling has been done. Again, according to the previous owner this setup currently is at 13:1 compression. It runs strong but I am used to it now and want a little more lol. If I decide against swapping pistons and keep the PCT's where would you guys say the limit is as far as cams go without p2v issues? Of course I will clay before I run it, but I'm just trying to get a feel of where my limit will be with the current bottom end.
To be honest OP I don't think anyone will make a comment on what cams you MIGHT be able to run. Everything is so unknown and up in the air. That 13:1 CR is based off if the block and heads are both virgin (highly doubtful). Only way to give suggestions is to clay and measure clearances. Fix-all is different pistons. Frees up a lot of stress and headache.
I also have seen mention of a toda rep header...should I be looking into a different header now or will mine be sufficient as I plan to upgrade cams after the bottom end is all worked out.
yes go with the jdm itr pistons and clay your motor with the pro2, like someone said if your surface are virgin youll be fine, but I doubt it. just clay it to be safe.
Not trying to argue, but he won't be able to find the JDM R pistons in anything over a 81,25 so the USDM pistons are the best option. RS machine makes them in 81.5 or 82 for less than $200.Those will provide more than enough compression anyways. I like to see 12:1 as the max for pump gas motors personally. Leaves more room for tuning IMO.
